Olympia Cremina SL - stronger spring - Page 2
i have to push upwards to achieve results i want.[/quote]
Agreed
Agreed
Lever User Since 1985
Hi guy's!
I ordered 4 springs from e supplier in Danmark. 2 stainless steel and 2 so-called piano-wire. I installed stainless steel a couple days ago and i already can se some improvements. Pressure is now about 1 bar higher. Piano-wire springs are about 20-25% stronger so i expect about 7.5 bar with these. I installed both regular size and small one. I'm gone test these for 3-4 before i install these stronger ones.
The one in the left is original.
- drgary
When you install the extra spring, how is it seated? Is there any complication with that?
Elektra Microcasa a Leva Review
Adding a heat break gasket on an Elektra Microcasa a Leva is so easy, though.truemagellen wrote:So Cremina SL with it's amazing temp stability and larger shot volume appears to be a greatly perfected version of an Mcal (where you battle temps without a heartbreak or other intervention).
LMWDP#308
LMWDP#308
Hi Gary
Before i ordered these i measured everything so that smaller spring fits perfectly between the shaft and spring. I do not feel any deferences when pulling the lever except its heavier to pull.
I'll been making espresso and lattes for a couple days no and quite satisfied so far.
- truemagellen
I am using one after ur suggestions in the past. Might even get to a stainless one proposed. I am going to try the new white strietman seal (it is a 2 oiece). It is a major improvement on the Strietman might make help Elektra.drgary wrote:When you install the extra spring, how is it seated? Is there any complication with that?
I can compare to a Cremina SL as my local friend has one.
Would you mind sharing the specifications of the springs you ordered? I'd love to power-up my SL as I prefer the higher pressure shots I make in the manual group.
Thanks - this is so great to see!
LMWDP #411
Hi. Spring specifications are as follows:
Outer spring
d:4,00 mm = wire diameter
De:29,00 mm = outer diameter
Di:21,00 mm = inner diameter
L0:130,00 mm = unloaded length
Ln:64,50 mm = max loaded length
R:13,34
Fn:852,20
Inner spring
d:2,50 mm
De:18,50 mm
Di:13,50 mm
L0:130,00 mm
Ln:58,90 mm
R:5,25
Fn:364,81
Material: Piano-wire, is the same material as original spring that comes with machine.
Springs er slightly longer about 5mm. Outer spring have about 13 threads and is 130mm long.
Original spring has 15 threads 125mm long.
Outer spring
R:13,34
Fn:852,20
Inner spring
d:2,50 mm
De:18,50 mm
Di:13,50 mm
L0:130,00 mm
Ln:58,90 mm
R:5,25
Fn:364,81
Hi guys
I just wanted to share a small video of an espresso shot with new springs. Im still testing but results so far are very promising.
LuanD: Excellent video, It seems your elegant solution will provide another choice to the Olympia SL concept of 6 Bar espresso.LuanD wrote:Hi guys
There has been other posts for the need of a solution to that-you have seemed to have potentially solved. Congratulations
Looking forward to follow ups.
