Odyssey Espresso (Argos Lever prototype) - Page 23
- baldheadracing
No. Machines are different, as are the strength and types of acids used for descaling. What you are describing would be catastrophic for some machines, but normal in others.titan wrote:So I understand that prevention is better than cure. But the process is to fill in the boiler with a solution, turn on the element, after boiler is up to pressure let it cool down, and then somehow siphon out the water, right?
video of a shot being pulled has been posted on instagram! The comments also include a confirmation that the included spring is 8 bar.
Why can't I view anything larger than a thumbnail on Instagram?
This is better: http://www.youtube.com/watch?v=R2E84-AyXxY
- pizzaman383
- Supporter ❤
That was a very long preinfusion - the same length of time as the shot.
Curtis
LMWDP #551
LMWDP #551
- GregoryJ
The machine and the espresso look really nice, but the shot looks on the small side. Obviously it's just speculation until they release more info, but I was hoping I would be able to get ~40-45g output.
Isn't 45g out hard even on big commercial group levers like the Bosco, Profitec Pro 800 and the LR?
You may have read it already, bit on instagram he said "I get anywhere from 35-55g out depending on grind and pre-infusion time and pressure". This one does seem a little short, looking forward to seeing more/trying for myselfGregoryJ wrote:The machine and the espresso look really nice, but the shot looks on the small side. Obviously it's just speculation until they release more info, but I was hoping I would be able to get ~40-45g output.
- truemagellen
It is around 60 with a healthy preinfusion on those machines. You terminate shots to your volume liking by removing the cup.megamixman wrote:Isn't 45g out hard even on big commercial group levers like the Bosco, Profitec Pro 800 and the LR?
- truemagellen
The problem with more volume and a spring lever is the spring becomes huge to compress more water. Then you need a huge base, a huge lever, and more power to compress it.
A Fellini leads to temp issues on dipper machines, not sure about this design which is a temp probed dipper correct?
The spring is seated inside the piston and is longer than it appears in some photos.
Ross has said that it has 1 inch of travel.
Given a 58mm group that is about 66ml of potential volume.
