Odyssey Espresso (Argos Lever prototype) - Page 61
Whew, this option is heartening. Call me mechanically challenged, a dolt, whatever you want, but I would pull my hair out trying to switch between the spring and manual lever and this ability to easily switch is one of two main selling points for me (the second being a temp stabilized grouphead). When I saw the Youtube video, I said, "no way," I'm not going to do this and even if I could there would be so many steps along the way where I would screw up or damage the machine. Then I read this message from Ross! What a godsend. The Argos is back on the table for me.ziptie wrote:From Ross's detail in the YT vid description:
"Those not wanting to mess with pins and retaining clips may purchase our additional piston assembly which ships in the direct configuration and drops in as a simple 1 minute swap."
Ross posted some graph of the temperature using a scace through pulling multiple shots in a row:
This is shot 2-5, shot 1 had a similar 95 -> 80 declining temp. I like the stability between the shots, but isn't this a big drop in temp during the shot? Anyone with a more informed opinion on how this looks?
edit: cut from this graph is a 30s recovery time between each shot
- retireddude
I saw that this morning too. Very interesting. The last two shots had a significantly lower temp drop, I'm guessing due to the group being hotter.
You should be aware that for any machine, the preinfusion phase only is guilty to cut about 10 C degrees, again, for ANY machine.
That because the three times difference between heat capacity of water and coffee (4.2 vs 1.4 J/gram/degree) and the 2-3 times the water quantity absorbed in preinfusion by a typical machine, for example 45-48 ml of water for 18g coffee in basket.
Putting the above in some equations result an average of 10 C degrees drop the equilibrium temperature of a saturated puck.
You simply can't saturate the puck without this temperature drop... it's only after saturation the temperature start increasing again, due to the continuous flow of hot water though the already heated puck.
So far nobody had the crazy idea to preheat the puck to save some degrees (and surely lose flavors), in the quest of ludicrous stability
Maybe I'm too picky but I don't consider 2-3C swings "stable". And the temp drop from 95C to 80C during a shot is huge. I'd like to see the 1st shot curve also.versusqc wrote:Ross posted some graph of the temperature using a scace through pulling multiple shots in a row:
Not picky, but unrealistic.
Did you read my post above ?
Sorry if not clear enough, not English native.
That's if you measure the water temperature at the puck or inside actually (water that has been in contact with the coffee bed), correct?renatoa wrote:You should be aware that for any machine, the preinfusion phase only is guilty to cut about 10 C degrees, again, for ANY machine.
I understand your point about the temperature dropped caused by the contact with the cooler coffee bed. It seems that from a design perspective, the temperature that's worth measuring is the temperature of the water inside the group as it's about to touch the coffee puck, no? What's referred as the brew temperature.
Just like we never hear about the temperature of the coffee pouring inside the cup.
Anyhow, we've seen scace readings of E61's, saturated groups, commercial levers, Robot, etc. Apples to apples the brew temperature drop during a pull with the Argos seems... Wide?
Actually, similar to the brew temperature curve of the Cafelat Robot... Which is not a bad thing but surprising given their design differences.
LMWDP #592
I don't know if it explains the temperature curve but in today's Arcps IG story, the brew temperature was set to 94c but the group temperature was (measured?) only 26c...K7 wrote:Maybe I'm too picky but I don't consider 2-3C swings "stable". And the temp drop from 95C to 80C during a shot is huge. I'd like to see the 1st shot curve also.
LMWDP #592
You are referring to the inevitable temp drop when water first hits the puck, which the plots don't show entirely because apparently he edited them out.renatoa wrote:Not picky, but unrealistic.
No argument there, but I am talking about something different: peak & avg temp profile shot-to-shot and intra-shot.
I like that they are sharing raw data, good or bad, like this, but data itself is quite disappointing to me. Maybe things will improve.
Plenty clear enough Excellent explanation.renatoa wrote:Not picky, but unrealistic.
