New-to-me VAM 1.0 (Arrarex Caravel)
vberch
#1: Post by vberch »
Yep, exactly! :) Francesco knows what he's doing!
Do you mind sharing some info on your PID? Mine is 220V and I was going to pull the plug (ha!) on a plug adapter and a 110V heating element from Brooks.
drgary wrote:Ha! I thought so.
Where else would you find such an immaculate example to add to your collection? (From Francesco Ceccarelli.) Congratulations, Vlad! That is the right 1.0.
I just pulled a shot on my Caravel 1.0, which is connected to a PID for excellent temperature control. The offset is about 10°F.
Mod note: Moved from Post a pic of your home espresso setup...
Click here to see here for pics of this beautiful machine
vberch (original poster)
#2: Post by vberch (original poster) »
Gary, I just saw your post re: 110V heating element: Temperature probe for a Caravel. I'm glad I didn't order it yet. Do you run yours with a transformer and a PID?
another_jim
#3: Post by another_jim »
Vey nice! All you need now is a Peppina to complete the 2 by 2. You have a spring lever with steam boiler, manual lever with steam boiler, manual lever with brew boiler, but no spring lever with brew boiler.
Jim Schulman
drgary
#4: Post by drgary »
Vlad, I've got the 110 v heating element and it is holding up. Since yours is more collectible than mine, you might want to run it in native mode on a transformer to avoid rewiring. Francesco could probably advise you well on that choice. BTW, for fast warmup, I quickly bring water to a boil on an induction range and pour that into the tank. From there it takes less than 10 minutes to stabilize.
LMWDP#308
#5: Post by vberch (original poster) »
Very true, Jim! Except the next one on the list is a Strietman CT2.
another_jim wrote:Vey nice! All you need now is a Peppina to complete the 2 by 2. You have a spring lever with steam boiler, manual lever with steam boiler, manual lever with brew boiler, but no spring lever with brew boiler.
#6: Post by vberch (original poster) »
Great advice, Gary! I've been boiling water in electric kettle and using my emersion heater to bring it up to temperature today.
drgary wrote:Vlad, I've got the 110 v heating element and it is holding up. Since yours is more collectible than mine, you might want to run it in native mode on a transformer to avoid rewiring. Francesco could probably advise you well on that choice. BTW, for fast warmup, I quickly bring water to a boil on an induction range and pour that into the tank. From there it takes less than 10 minutes to stabilize.
Ben Z.
#7: Post by Ben Z. »
I run my 220v caravel with a pid and transformer. First I wired the transformer to the pid and then from the transformer to the caravel. It works, but it makes a noise every time the pid calls for heat. Better to have the transformer first and then use the pid on 220v. Seems obvious now, no idea why I tried it the other way first.
JohnB.
#8: Post by JohnB. »
I put the Brooks 110v element in my early Caravel & haven't had any problems. I run both the Caravel and my La Peppina through an Auber-WS pid temp controller.
LMWDP 267
#9: Post by vberch (original poster) »
OK, I have a potentially stupid question :).
Does it take approximately the same time to come to temperature using Brooks 110v heating element and using VAM original 220v heating element on a transformer?
Ben Z.
#10: Post by Ben Z. »
If they have the same wattage, performance will be the same. On their website the 220v is 550w, but the 110v one doesn't have watts listed...
