New La Pavoni Esperto Line - Page 3
OldNuc
#21: Post by OldNuc »
bas wrote:I am still liking that other 2nd generation temp mod discussed here:
Heat control mod for 2nd Generation La Pavoni Levers
Basically this mod converts a 2nd generation machine to 3rd generation one. That means a concersion from a steam vented to hot water saturated group.
I am running my 2nd generation Pro at 1.0 bar max pressure. The only thing I need is a cold PF. Same workflow as with the Millenium I had.
This mod is quite simple and will produce amazing temperature control and stability. It effectively routs the area above the piston to just above the heating element so the group is no longer heated continuously by condensing steam. If you want to be able to pull multiple shots in close succussion this is the easy way to do it.
