Mini scale for Cafelat Robot - Page 10
HELP?
Newbie robot user (old barista) here. I bought this scale based on recommendations here: https://www.amazon.com/gp/product/B00GT ... UTF8&psc=1
But it turns off automatically after 60 seconds, even when I'm in the middle of a shot!
It seems like (a) this is a popular scale for the robot and (b) this auto-off "feature" would be a deal breaker. Once I get the scale set up ready to pull a shot, pre-infuse, and start to pull, I often get to 60 seconds before I'm at the desired 2:1 weight in the cup.
How are others using this scale with their robot? Am I missing something?
I don't have that exact scale but that "helpful " feature is pretty common. The way they usually work is they stay on as long as the weight is changing. But pulling a shot is too gradual a change for it to notice. If you will put a finger on it to make a big change just before you start your shot, you now have a full minute of actual shot time which is hopefully enough. If you are doing an extra long shot you may need to bump it again as you go.
- drgary
It looks like it has a tare button. You could press that chest at the start of the shot.
LMWDP#308
LMWDP#308
Good tips! Thanks, both. That will tide me over until I get that new scale with the timer...
So I have been using the Taylor scale and my issue is the same it shuts off after like 60 seconds.
https://www.surlatable.com/salter-compa ... 25507.html
Do we have any more accurate scales that do .001g Vs. 01g? Or one that won't auto shut off?
Typically I push on it mid pour but that means I have to take my hands off the bars.
I like the sexiness of the Pyxis... But really $260 for a scale that we can pay $30 for?
I use a 500x.01g pocket scale. It also shuts off after 60s but never during a shot. All it takes is a single drip to reset its timeout. I like the extra precision vs a .1g scale when I weigh the dose. But I think I'm in the minority.Bombadilio wrote:Do we have any more accurate scales that do .001g Vs. 01g? Or one that won't auto shut off?
A .001g scale would be overkill.
I agree with this.. I like the 0.01g scales as they are generally quicker (track the weight faster). Some of the American Weigh scales I tried (0.1g) were brutally slow. I now just get the ones mentioned above at amazon for about $20
The new Decent Bluetooth scale is 4" wide.
I don't own a Robot (although I'm sorely tempted just for yucks) so I can't say if that would fit or not.
Even if the decent scale was a quarter inch narrower it is way too tall for the robot.
Is a hundredths scale really faster than a tenths scale, or does it only appear to be since the hundredths digit is faster?
I have a Maxus brew scale that I once used with my robot. Fits perfectly and it has the ability to allow different sleep options. Never turned off for me while in use. It is a tenths scale though, maybe they make a hundredths too. One has to be careful with these clone scales as there are some lookalikes that turn off.
Mine is an American Weigh Scale and it has a noticeable lag. If I am aiming for, say, a 32g shot I stop pulling around 31g or so.Bluenoser wrote:I agree with this.. I like the 0.01g scales as they are generally quicker (track the weight faster). Some of the American Weigh scales I tried (0.1g) were brutally slow. I now just get the ones mentioned above at amazon for about $20
The Decent Simple scale looks way faster. And you can program it so that it doesn't shut off automatically. Unfortunately it's specified width is 10.0cm which is about 1mm too wide for the Robot. Maybe it will fit anyway?
