Mini scale for Cafelat Robot - Page 3
Yes, there is definitely some lag time, but with the robot, I am really not too concerned with hitting the perfect time. . For the price and the functions that it offers it's a great buy.mlunsford27 wrote:How's the response time of the scale? do you feel like it lags behind and is hard to hit a particular weight?
Julia
The key to keeping these scales "alive" during a lengthy pull is to firmly touch the scale (or push down on the rim of the cup, atop the scale) to keep it actively reading a significant amount of weight; the slow "drip-drop" or thin run of espresso weight is sometimes not enough increase in weight to keep the scale going during a longer pull. Give it a firm push every 15 or 20 seconds, and in my experience that keeps it weighing, without cutting out mid-pull.vit wrote:Can you say how long it stays turned on?
I bought a small pocket/jewelry scale from ebay (it was more or less the smallest available) for a few $ for usage with Flair, because the width of drip tray within the stand base is also limited.
https://www.ebay.com/itm/500g-0-1g-Mini ... ctupt=true
Tried it once. Precision is ok, but I turned it on about 40s before I started the pull, and it turned off about 30s into the pull. So this one not recommended.
Yes, I know that ... but my older scale is staying alive long enough, so it would be nice to have something similar ...
It's 2.9" wide. So it should fit... in theory!jpender wrote:I have a 500x0.01g scale that at 4.4" would fit, in theory. It was also around $15 on amazon. A good scale that has proven itself to be both accurate and reliable over a period of many years. I've traveled with it, dropped it. It keeps working very well.
It appears the price has gone up a bit:
https://www.amazon.com/American-Weigh-S ... 0012TEQMG/
It suffers from the same non-adjustable auto-off feature as many of these small scales. This one turns off after 60 seconds of inactivity. So you'd have to turn it on within a minute of starting the shot. But since it's a centigram scale it wouldn't shut off in the middle of a shot, even if it were just dripping into the cup. And the response time is pretty fast.
If/when I get a Robot it's what I plan to use, assuming I use a scale at all.
Mine stays on indefinitely (or at least several minutes) if I continue adding or taking off weights of several grams. Unfortunately, slow espresso flow isn't enough to keep it alive
- Alan762
My old $20 scale finally died after almost 2 years of daily soaking from the E61 pressure release water. I am amazed it lasted as long as it did.
Couldn't find a new one so I ordered one of these.
It never gets easier, you just go faster. "Greg LeMond"
I must confess using this scale is adding a wee bit to my stress level.
To insert the PF/Basket, I have to remove the cup, then then add it back. I'll see if I can get used to the extra couple steps. Thing is, the Robot is so blood simple..once your routine is locked in...that it seems almost counter-productive to get as fussy as weighing lever shots. Semi auto, yes, weighing is great as the shot stops immediately. I'll work at it, and see if I can get it right.
Yeah the whole squeezing the portafilter in is a bit annoying....especially when you get into a declining temprature panic and...it...just...won't...lock....
I got these:
Ewolee Digital Pocket Scale - 500g x 0.01g Smart Jewelry Scale, USB Charging Multifunction Digital Scales with LCD Display and Tare Function, Stainless Steel for Accurate Gram and Slim Design https://www.amazon.co.uk/dp/B01N7GC8SZ/ ... yCbSKBNXVX
Pretty slim so I can still fit the Motta shot glass and squeeze PF in without taking glass away.
I got these:
You must be less clutzy than me, I always preferred to keep the cup out of he way while locking the portafilter in even when not using a scale. I do use a largish cup though. For me I think the time is probably a wash: I imagine I save as much time having stuff out of the way while locking the filter as I lose by needing to move the cup + scale over.IMAWriter wrote:I must confess using this scale is adding a wee bit to my stress level.
Ha, Nate, I ASSURE you I'm am klutzy. As to the cup, I've been using Brewista's glass double walled cups which are tall, and don't allow a lock in with the cup on the scale. I had a good session, by overheating the water a bit, leaving the scale on the Robot/silicon mat...pouring the hot water in, placing the cup on the scale...Tare...and pull...
I was able to stop the shot within .4 of my goal..early..I'd rather be early than late with this particular SO. Thankfully, it registers the first drips...after about 2 grams hits the cup.
