Microcimbali boiler fabrication
Many people have been trying to solve the problem of "rusting to dust" of the Microcimbali boilers but even my own research proved there are no simple solutions. There is already a 3D model on thingverse but printing it in metal proved too problematic and expensive. I own two microcimbali machines and it bothered me for a long time that I cannot use them due to the boiler being so fragile and rusting away. Therefore, I decided I would fabricate it. After approximately two months of intensive night labor (after kids were put to sleep), I finally have a working prototype. It is made completely out of stainless steel. My workshop is not well-equiped for metal work and my welding is far from good but I made it. Along the way, I am developing a simpler, more streamlined solution for further fabrication. For the first one, I made all of the components myself from tubes and sheet metal, for the other one that I am about to start putting together, I let a dedicated company to precisely laser cut these components and I hope the assembly will be much easier. At this point, I use the boiler non-pressurized (gravity fed) mostly because the water level indicator must work with open upper end (since it only has an inlet). One of the pictures shows another version with a simple oil level indicator in a form of a see-through nut. I need to strip it out of zinc and plate it with nickel and then, I will try to use the boiler pressurized. The biggest challenge during the fabrication process was to make all the welds watertight and then seal properly the group head. It took several trials with various gaskets and materials but it holds tight now.
I have read on forums that reviving microcimbali is not worth the effort because the machine is simply not capable of producing excellent espresso. I had that experience as well, especially in comparison with other levers that I own (pavoni, caravel, peppina, faemina) but that changed with my new boiler and specifically when I modified the spring tension on the piston (increased it). After that, it produces great espresso.
- TomC
Very cool! You've done a commendable job!
I am still stumped that there hasn't been another plating material identified that is less prone to corrosion that would work.
- drgary
It's great to see an actual solution to the problem with boiler materials. I'm thinking that the cause of not making good espresso was a de-tensioned spring. The Microcimbali I restored made excellent espresso and steamed well in its stock configuration.soldjem wrote: I have read on forums that reviving microcimbali is not worth the effort because the machine is simply not capable of producing excellent espresso. I had that experience as well, especially in comparison with other levers that I own (pavoni, caravel, peppina, faemina) but that changed with my new boiler and specifically when I modified the spring tension on the piston (increased it). After that, it produces great espresso.
LMWDP#308
LMWDP#308
This is amazing work and you deserve alot of credit for taking on such an intimidating task successfully. Can you make a boiler for mine too?
Thanks much! I still have three sets of laser-cut components and eventually plan to make more but I cannot say when. It is a night time job for me after kids have gone to bed. I can have more sets cut by the company too. I can offer once I have some of them done.
- drgary
This looks like a home project and not the start of a business. With that understanding, please know that we ask members to post items for sale in the Buy/Sell forum if they are not a business. We ask members to request to buy items there and not in discussion forums elsewhere on the site.
Lukas, if this ever becomes a business, please contact Dan Kehn, our site owner, aka HB, to set that up.
LMWDP#308
LMWDP#308
Gary, this will never become a business. I have my day job and fight for time as most other people. Home project yes and if I would offer, I will do it in the buy/sell forum as instructed.
Thanks
Thanks
great project!
I am thinking about doing something similar to a dead microcimbaly (hole in the boiler due to corrosion)...
a question about the welding: did you back-purge while welding the boilers?
and how did you connect the two boilers in the second version? i could not see ane welds there...
Thanks!
No, I did not back-purged the welds. The tubes are very short, purging would be quite difficult to set and most importantly, I removed any oxidation around the welds that would be prone to corrosion by electrolytic polishing with an acid to restore the surface chromium oxides.
The second boiler has welds around connecting tubes only inside the boiler. I wanted a cleaner look and made the holes precise enough that the fit between the components was quite nice.
After half a year of daily use, both boilers are serving without issues.
Cheers
Cheers
