Major Gaggia Stuff-up? - Page 2
Just to add to the knowledge base, the early ones like mine only have two chrome fixing screws to each side panel instead of the later four per side.
Here's another one.. You can just see the two side panel screws and the sight glass window is slightly narrower.
"24 hours in a day, 24 beers in a case. Coincidence? I don't think so."
There is some detailed info hiding on this site: https://www.kaffee-netz.de/threads/gagg ... en.109856/ Registration required to be able to pull up most pix.
Thanks! Cool sight and I already found something I didn't know I'm missing. That little metal ball that goes in the fill valve. Still seems to work okay though I'd like to know where it goes. And now I need to learn German.
The ball is probably a back flow preventer check ball. No idea of its exact location though.
Well, it seems like it would be prone to fall out of there rather easily.
The lever is at it's most extended in the photo and the ball is sits in grooves / hollows so it can't fall out. It is inserted through the body of the valve while assembling.
John
- Paul_Pratt
I wonder if their is a float that goes in the glass? Just a crazy idea. Haha would have to quite long and stick out above the water around 2 inches.
Might be a float with a thin SS wire out the bottom with a small colored bead on the bottom end of the wire so when the little bead is at the full mark on the visible sight glass the actual level is at the true MAX level. Would be easy to construct such a float.
