LUSSOCLUB Chimera
- Bluecold
Looks like an frankenstein from an Olympia and a Sama.
The group looks Sama, the boiler looks olympia. The bottom and drip tray look Sama, but the front plate Olympia (wider). The rear cover then probably is widened.
I based my conclusions on the pictures found here and here
LMWDP #232
I'd have to agree with bluecold on this - I've got a Sama Lusso (with a problem boiler, so I've spent enough time examining it) and I was just looking at the innards of an Olympia Club this weekend.
Not a bad looking frankenlever if you ask me - should be quality parts all 'round. Provided it fires up and gets to pressure with no major leaks, it could well be worth your while if the price is right...
- timo888
Yes, the machine does have a number of things in common with the Oly Club: high-quality drip tray (Samas tend to be flat plates with small holes drilled too far apart to be of much use), easy-access boiler fill neck (Samas require the top to be removed); knobs on front (Samas have them typically on the sides).
- orphanespresso
- Sponsor
We have the identical machine called a La Romana, and I had assumed it was made by SAMA, but with Timo's description it doesn't sound like a SAMA manufacture. Same shape knobs, same layout and boiler, same pstat, and likely the same seals, unobtainium and redone using our secret recipe locked in a vault with the Colonels secret chicken spice formula......nonono....I got enough grief over the pin pulling thing....but the machine does look like the La Romana, and we have seen pics of a machine also identical in Australia of a La Musette. No information on the manufacture of either machine but it is the same as this Samalusso made my Olympiasamavecchio.
Doug Garrott
www.orphanespresso.com
- peacecup
What is the diameter of the basket. The group looks like a Ponte Vecchio, but the diameter looks larger, like a 49mm
LMWDP #049
- timo888
Back in ought-seven, I had custom u-seals (45 x 35.5 x 7mm) fabricated by a small company in Austria, using white FDA food-grade EPDM. Pricey in small quantities, especially since I ruined a couple trying to put them on the piston not having the right tools.orphanespresso wrote:We have the identical machine called a La Romana, and I had assumed it was made by SAMA, but with Timo's description it doesn't sound like a SAMA manufacture. Same shape knobs, same layout and boiler, same pstat, and likely the same seals, unobtainium and redone using our secret recipe locked in a vault with the Colonels secret chicken spice formula......nonono....I got enough grief over the pin pulling thing....but the machine does look like the La Romana, and we have seen pics of a machine also identical in Australia of a La Musette. No information on the manufacture of either machine but it is the same as this Samalusso made my Olympiasamavecchio.
