Announced: Londinium Compact. - Page 21
Yes that's correct, I should have said it doesn't have "fancy" preinfusion" due to the lack of digital preinfusion of the L24 or line pressure preinfusion of the compressa.mathof wrote:It will have pre-infusion at boiler pressure, as does the original L1.
its a tricky machine to place,
it can be made to be as good as a lr24 or you wouldn't spend the extra £3k
be interesting to see how it stacks up next to its rivals
There aren't any relationship issues, the poster disliked the londiniums so much he had 4 of them! And in terms of reiss doing nothing in terms of the development, that is another fairy tale. Reiss is directly involved in the build process and it's his specifications that fracino build the machines to. And as a supposed box shifter! You really find a better level of customer service from any other "box shifter" or retailer.PhilthyCoffee wrote: I'm aware of the Fracino relationship, but not to great extent and I don't know anything about them apart from them being mentioned on the Londinium Vectis thread. Can you elaborate a little on the known issues with this arrangement/Londinium in general?
levers levers levers, is there any other way?
or we can ignore that,
and talk about the positives that its almost here and working.
Completely agree, I hope it lives up to expectation
Can't wait to see a side by side comparison with the Argos Odyssey. Both machines should be available approximately in the same time.
- HB
- Admin
I've removed the last few posts that contravene the site's Guidelines for productive online discussion.
- TigerStripes
It will have the same preinfusion style as many other dipper machines such as la pavoni, la cremina, and profitect 800, to name a few.PhilthyCoffee wrote:Yes that's correct, I should have said it doesn't have "fancy" preinfusion" due to the lack of digital preinfusion of the L24 or line pressure preinfusion of the compressa.
If you prefer 3 bar preinfusion, instead of 1 bar preinfuse, you can release the lever slowly so that the piston doesn't immediately go up to the full pressure of the spring. It may be tough to gauge that pressure without a display gauge, but it can be done by feel and seeing what is happening at the basket with a naked portafilter.
I don't really see less complex preinfusion pressure as a downside. It's simply a different approach. I used la pavoni's for a while and found the boiler pressure preinfusion to work quite well.
If this machine really is under $1500 usd, I will be very excited to own one!
LMWDP #715
