I joined the LMWDP club with the Robot as an easy entry ticket, but I felt like a stranger here without a spring lever. So what did I get ? A good deal on a basically new Ponte Vecchio Lusso. The reviews and comments here helped a lot to make a choice.
Concerning the build quality, I can confirm the rough finish, for example at the water tap wand there's a small (silicone ?) ring at the junction of the body which is a little bit loose (might have to put some glue, but it's barely visible). No big deal for me. It does seem like it's best not to rely too much on the drip tray. Concerning the hot water tap, I only have one warning: it's hot water coming out faster than one would think
EDIT: I also found that there is little bit of play with the lever which I can slightly rotate towards the right, so that it's not perfectly centrally aligned with the machine when pulling it down
I have not timed it but the boiler felt like it heats fast. The pressurestat is set at 1,2 bar. The PV Lusso comes with a nice metal tamper, the fit is appropriate. It's too soon to comment on the quality of the shots or steaming, I'd probably have some questions on a separate thread.
In the future I might add a bottomless portafilter (I don't have the tools to cut the double spouted one) and some baskets depending on which ones get used the most.
Now that I have to use good water (the Robot didn't care
), I crafted proper espresso machine water with distilled water according to R. Pavli's recipe with a concentrate I diluted.
I can't wait to discover more about this machine
