Lever Espresso Machine Gallery - Page 311
Thank you all for the kind words, she arrived today and somehow I feel charmed!
Nope it isnt the original but powder coated
Nice! Way to start.. with PPK and the isolator installedGataros wrote:Today i join the lever ''club''.
My 1983 LP professional with the PPKit![]()
Osku
The one thing i have noticed is that i definitely need the temperature strips.
Almost all the time, the first coffee i make is somehow not as hot i would have expected.
After my funnel comes, i will be able to fill much better the basket, since now i create a mess all over the kitchen counter.
From my extractions, it is evident that my distribution needs a lot of work.
As a first observation, the mouthfeel of my espressos is much smoother compared to a pump machine.
- bcrdukes
Wow, very nice machine!
The bottomless portafilter - is that a factory cutout? Or an aftermarket version?
LMWDP #685
Are you releasing some steam after it first comes up to pressure? If not, the "false pressure" may prevent it from heating up enough.Gataros wrote:The one thing i have noticed is that i definitely need the temperature strips.
LMWDP #717
bcrdukes wrote:Wow, very nice machine!
It's an after market version combined with an IMS basket:
https://coffee-sensor.com/product/la-pa ... ter-49-mm/
grind727 wrote:Are you releasing some steam after it first comes up to pressure? If not, the "false pressure" may prevent it from heating up enough.
Yes I have tried as a general rule to release some steam, wait for the boiler to recover, then lift mid way the lever for the GH to heat, however when I make the first coffee, I don't get this warm close to burn feeling an espresso should have.
Get a GH thermometer, and this discussion to another topicGataros wrote:Yes I have tried as a general rule to release some steam, wait for the boiler to recover, then lift mid way the lever for the GH to heat, however when I make the first coffee, I don't get this warm close to burn feeling an espresso should have.
Osku
