Lever espresso machine designs - Page 3
pizzaman383
Supporter ❤
#21: Post by pizzaman383 »
drH wrote: This is a cool idea. It doesn't seem too far off from what ACS is building with their dual boiler Vesuvius lever. That will have 3 PIDs; 1 for the brew boiler; 1 for steam boiler, and 1 for the cartridge heaters in the cylinder/group. On top of that the pump will deliver adjustable preinfusion pressure up to 5bar. You can see Dave Corby pulling shots on the prototype test bed if you search YouTube.
I built a 3-PID lever group machine much as you described. It still operates much like a classic dipper lever with different temperature control methods.
The difference between that and my proposed design is that the new design would operate closer to a saturated group because heat for the brew water and the group head would be from the same heat source.
Curtis
LMWDP #551
Paul_Pratt
#22: Post by Paul_Pratt »
This thread is very confusing unless I haver misunderstood what the crux is. The LSM group does not behave the way a Strietman/Faemina does, it merely has a separate valve that shuts off supply to the group. It eliminates the need for extra piston seals and it only has 1. The piston still has to clear the hole at the top of the stroke and at the same time the extra valve is opened allowing water to flow through.
