Lever arm won't stay up
tusker123
#1: Post by tusker123 »
I recently rebuilt my La Pavoni Professional and found that the lever arm slowly falls to the down position after lifting. Does this mean I have an improper seal somewhere? The lever does stay upright after the preinfusion.
mrgnomer
#2: Post by mrgnomer »
My Cremina 67 and LaPavoni Europiccola both have no springs. The normal lever position is down. Only after using them and they're turned off for a bit I think a vacuum develops and the levers creep up and they only do that when the piston seals and chamber are fairly clean and lubed.
Kirk
LMWDP #116
bakafish
#3: Post by bakafish »
Nothing wrong. Instead, like mrgnomer said, it means the piston seal and chamber are clean and lubed very well if there is no leak.
yakster
#4: Post by yakster »
It's rare that they stay up. You'll see this if you have freshly replaced the gaskets and it makes a good seal, but normally the lever will relax into the down position.
-Chris
LMWDP # 272
