Learning with inherited Elektra Microcasa a Leva - Page 4
- IamOiman
It's all in that thread I gave you.
I had the lever taken off with just the fork remaining on the group. I was able to compress to the point I took a small rod with a similar diameter to the fork pin and with a little mallet knocked out the fork pin without much trouble.
-Ryan
LMWDP #612
LMWDP #612
Ok thanks.
Ya read through it, was just trying to mentally visualize what order you take the pins off as you compress the spring on the jig.
I guess the small pin gets moved up as the spring is compressed so it clears the jig.
Thanks
Waiting now for the spring to come..
Thanks
- IamOiman
Ok thanks!
Another thread described a similair jig, but instead of wood at the top, he used the two holes in the plate (with washers to avoid scuffing it).
The two holes that you use to screw the plate back in to the grouphead.. That would maybe give more clearance, but yours looks like no problem either.
Can I ask which specific tool you used to remove the circlip (seeger clip).
My snap ring pliers don't fit in those very tiny holes...
Thanks!
Thanks!
- IamOiman
I used wooden chop sticks and pushed the clips out on one side
-Ryan
LMWDP #612
LMWDP #612
Ok I think I got this machine working properly.
I have now changed all the gaskets, and then today I changed the spring.
I am (finally!) getting what I think are good shots, with the lever taking 20-40 seconds to go up depending on my grind and tamp.
Thanks to everyone for help!!
I have one last problem. I can't get the darn seeger clip on the large pin. It is too strong for my fingers, and too small for my retaining ring pliers.
Anyone have a trick to get this little guy on? I'm using the one that stefanos is selling..
- IamOiman
I use chopsticks and press against the edges with them.
-Ryan
LMWDP #612
LMWDP #612
From looks of your picture you have e-clips... Stefano sent me these circiclips.. I think the chopstick won't work on those..
- armindillo
