Lapera DS lever first look. - Page 2
I like that manual boiler drain valve idea. Like they say, why isn't this on every machine?
Ha. Well they will be very different. I think the Cremina will still have its niche as the perfect compact manual fill, manual lever dipper.
But lapera seems to share the quest for top build quality while being spring driven, HX, temperature stable and plumb-only. Maybe you can find room for both?
- bcrdukes
I was afraid someone would suggest this!drH wrote:Maybe you can find room for both?
LMWDP #685
You might just be underselling Thomas's achievements a bit!jwCrema wrote:The Niche Zero of levers is forthcoming?
It looks a magnificent machine with a perfect mix of retro looks and modern production methods.
- redbone
I can confirm that Thomas used premium commercial wiring. Company I work for which distributes CSA and UL approval wiring to manufacturers also supplied Lapera with industry grade and approved high temperature wiring.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Lots of dimensions to this - I was thinking about a cult following and difficulty in acquiring one.LuckyMark wrote:You might just be underselling Thomas's achievements a bit!
The website was rather doggy when I last tried looking at it and gave up. As a result I didn't see that it will be "plumbed in only." That would be a deal breaker for me personally.
- redbone
Absolutely gorgeous. I've been on the hunt for a "proper" espresso machine for awhile now. The journey is the reward. I've narrowed it down to two machines, the Olympia Cremina ML or the Decent. Just over the horizon will be the Londinium Compact too. I just discovered this Lapera DS. I have a Kafatek MC4 all dressed up in black and a Lapera DS in black would be the perfect accompaniment. Thank you for posting all the different color possibilities. The dimensions of the Lapera are nice and compact too. As others have said, plumbed-in only will be a deal breaker for me too. I'm already thinking, can the bottom base be color coated to match the sides? Hello Pantechnicon! I can't wait to hear more news on the Lapera DS. Keep in coming.
- Psy
I'll second this :]IamOiman wrote:If it's orange and a lever I probably want it
Looks really nice, and I would like a modern machine at some point. I'll be curious to see if there are non-plumbed in options that become available as well.
