La San Marco Open Source Lever Machine
I would like to introduce my take on the Open Source Lever Project (OSLP) started by Andre (Open Source Lever Project). I am grateful for all the ideas and discussions that went into the original project by Andre and other members of HB. The OSLP was started at the right time for me, as I would otherwise have ended up with a commercial lever machine and missed all the fun of a DIY project
Many of the priorities and considerations for the design were discussed in the original OSLP thread, by Curtis in the thread about his lever build (DIY Dipper Lever) and I have been communicating with Jorian (From Scratch DB Home Lever) as well since he was also using the LSM group for his project. Credits to everybody for sharing their ideas and experiences!
Current version (steam is not connected yet)
Overview of the main components for the build:
I am really happy with the way this came together and loved the espresso I was able to make right away (so I kept going). I do not have access to a lot of specialized machining tools, so everything for this build was created by me with hand tools and off-the-shelf components (and hours of hands-on work). I am still working on a bunch of smaller things and will update with more data on temperature stability etc.
Thanks for reading this far and please comment or ask questions... cheers,
Thomas
La San Marco lever group
Adapters for cartridge heaters
First prototype making espresso
Making the front plate using a hole saw
And finally the concrete base with the Unistrut frame
- La San Marco lever group. The group I got appears to have a new design that includes a sleeve with three entry points for water into the cylinder. It also has an extra seal (quad seal type) on the spring retainer compared to the documents I have been able to find on-line (see pictures below).
Ascaso 110V/1000W thermoblock (same as the OSLP).
Active heating of the group using two 110V/100W cartridge heaters attached to the group using custom aluminum adapters.
Temperature management by PID control with solid state relays (SSR) of both TB and group using Arduino (easy data collection).
Frame build from Unistrut with steel front plate and concrete base.
Thomas
- Sponsor
First of all, Thomas this is amazing! I know I emailed you already, but I really love the concrete base, to me it is genius! I've seen some very nice concrete counter tops in kitchens, so I know you can polish them and coat them to get them shiny if you wanted.
I'm also liking the LSM group a lot. In some ways, I do wish I had gone with that. Wheels are turning, and even though I've got my plate full with other machine builds, I'm thinking of re-building my machine already with a smaller plate to heat the group. Really digging the concrete. CONCRETE!
Bravo, very nicely done. I love your project (as well as EspressoForge's). Thanks for sharing.
Your concrete solution is great.
What an amazing project, well done!
Can I ask where you sourced the wooden handles? I have a La San Marco 85 leva coming and would love to upgrade the plastic handles.
Cheers
Ralf
Cheers
Ralf
- TomC
Nice project!
I'm jealous of your group sleeve with it's 3 well spaced inlet ports. I'd love to see a group flush if you can. My Izzo Leva just has two small holes in the front of the group (at 6 o clock if looking up from below) and the gush of water is rather chaotic. I try to mitigate the aggressiveness of the water entering the group when extracting by very very gently easing into the spot in the pull where the piston slides past the inlet ports and lets water enter. IT seems to add some forgiveness factor to the extraction's pre-infusion evenness, especially on all my large flat grinders.
I imagine it wouldn't be impossible to swap out group sleeves, but it'd probably be cost prohibitive and difficult to acquire.
- Sponsor
I'm reasonably sure the spaced holes don't matter as much as the volume of water and pressure behind the group. My Bosco group I think has 3 holes and the water tends to rush in, even with a needle valve to control flow. There's just a split second where water will shoot in, then it starts going to the lower flow rate. My experience is also that the initial flow matters a good amount.
- TomC
Both the Bosco and the L1 have holes that are smaller and nicely spaced out. You should see the ugly, rapid flush the Leva does. It does make a difference. It's mitigated by going slightly slow till there's a small bed of water laying flat on the puck, but just rapidly pulling the lever down (or in essence, pulling down like any other normal lever) puts quite a turbulent blast of water right on the puck. Once there's a small "table" of water on top, it doesn't matter anymore.
Thanks for the compliments - I had the pleasure of pulling about 10 shots back to back today and the temperature recovered consistenly. I am out of town this weekend and will get the computer hooked up next week to collect more data. I need to make a thermofilter to get a better idea of the brew temperature as well.
Ralf, I got the handles from espressoparts.com. They have both M12 for the lever and M10 for the portafilter.
TomC, I will make a video with the group flush next week.
Hi Tom,TomC wrote:Nice project!
Please see the video below for a flush when the machine is at brew temperature. How does it compare to your group? Does your group have a sleeve as well? I have not been able to find any information about the sleeves for the LSM group and don't see them in the diagrams on-line.
