La Pavoni Pro in the hands of pros - Page 4
I love how this thread just wouldnt die.
few things i would like to share on pulling with La pavoni
1) I had given up on pulling doubles, realized there is no way to pull a perfect double espresso with 1.5 pulls / 2 pulls, or whatever methods already suggested
2) 11.5 - 12g to pull a single w/ double basket, simply because you cant dose 9g on a single basket, filter wouldnt be able to lock in place because the single basket is too shallow. if you dose 9g on a double the puck would crack because the gap between puck and shower head is too large. After bags and bags of trials and errors i figured ~12g in a double basket work best.
3) grinds finer than ordinary machine. I used the same grind same bean on my gaggia classic and it'd stuck.
4) agreed on 40-50lbs of pulling force.
This thread has stayed alive surely because it's still informative, useful and entertaining. I only came across it this morning, and somehow brought to mind:
But particularly welcome, especially coming from Chris, was his confirmation this elegant design could produce espresso that's as fine as with any alternative method. Not that it's easy or - without care and effort - consistent, but this is also part and parcel of lever-users' esprit de corps (in for a penny, in for .1g).
Adding a few notes from my own experience:
Regardless of whether the La Pavoni is or isn't an espresso lightsaber, for most of us who wanted to make good home espresso back in the mid '70s, the La Pavoni was the only option we could find. Mr. Tacy's comment about it being the "least practical home machine" just didn't apply back then, so we all went through that journey and figured it out. That said, there are options today that ARE more practical and straightforward, and that will likely provide a better result when you don't go all the way or if you aren't given to OCD-driven technique.An elegant machine, from a more civilized age...
- Obi-Wan Pavoni
- * Finer-grind / lighter-tamp has also brought out the best for me.
* Longer pre-infusion works well - up to ten seconds with some coffees, and don't worry if there's no stream or drops up to that point.
* Don't pass up the LP's capability for pressure profiling during the shot! Particularly with high-toned Central American SOs and citrusy blends, pushing that lever really hard at the start then easing up after about the first third of the pull can bring some wonderful balance and depth I can't replicate with static pressure - or with the GS/3 for that matter.
* Regarding lever pressure in general, F.M.'s analogy (early in this thread) of cutting "soft cheese or fresh brownies" is great. Mostly, I just put both hands on the lever and without pressing down, just letting that weight do the work.
* The old Rocky works great with the LP. Even after using the Macap M4 and then the Macap M7K, the Rocky paired better with the LP. (Explaining this anomoly in the "...Beat the Robur" thread, it was proposed that the larger proportion of fines turned out by the Rocky may optimize performance in small baskets, but all I know is the results taste great.)
* You will likely find your shot quality is proportional to the care with which you grind / dose / level / tamp. I think the 49mm baskets (pre-Millennium) just don't leave much margin for error, and I actually sift the coffee into the basket (outside the PF) then tap the bottom corners of the basket a few times to settle the grinds (and maybe migrate the fines downward - who knows), then level and tamp with a flat bottom. (Note that Orphan Espresso's proposals for simplified preparation (outstanding and a breath of fresh air!) dispensing with much or even all tamping could well be valid for you, especially since the LP employs a flat and screw-less dispersion screen. For a while, I just skipped the tamp altogether and let the dispersion screen establish the level and "tamping" the bed as the PF tightens in. But my own mileage varied and I went back to the extra step or two, at least when using the La Pavoni.)
* A bottomless portafilter is especially rewarding with the La Pavoni (or any lever machine), providing instant visual feedback on the effects of your lever pressure. See RayJohn's hole-saw manufacturing method, which is easy, fast, and works a treat with pretty results; I wish I'd thought of that 35 years ago.
- RayJohns
You're too kindAnvan wrote: * A bottomless portafilter is especially rewarding with the La Pavoni (or any lever machine), providing instant visual feedback on the effects of your lever pressure. See RayJohn's hole-saw manufacturing method, which is easy, fast, and works a treat with pretty results; I wish I'd thought of that 35 years ago.
Speaking of the La Pavoni, I recently ordered an Elektra single shot (and double shot) 49mm portafilter basket (From Stefano's http://www.espressocare.com - quick shipping, excellent parts, service; recommended to me by DrGary) for my machine.
Anyway, the baskets were great! Very well made and fit perfectly with the 49.6 mm Reg Barber tamper(s) I have here.
But the real surprise was how much of an improvement the single shot basket made on the espresso. I don't know if it's because it's matched better to the ~ 30 ml size of the group head or what, but it seems like pulling shots with 8 grams of coffee in the single shot (i.e. the necked down) basket produces just a fantastic shot (compared to the normal 12 gram basket that my machine came with). I also have the double shot basket (which holds 14 grams no problem), but so far not a lot of luck dialing that in.
For anyone learning on a La Pavoni, I definitely recommend the naked portafilter mod and also investing a few bucks into an Elektra single shot portafilter basket.
Ray
- javaman
Ray,
I was really surprised by your comment. The FIRST piece of advice people gave me regarding the Europiccola was to ignore the single shot basket and only use the double even for singles. Many people said it was impossible to get a good shot with the single basket. Is the Elektra single basket bigger than the one that comes with the La Pavoni?
Has anyone else had good luck with the single basket?
- drgary
I use the single basket often. It's not hard to do. I like this if I want a little pick-me-up or if I'm dialing in a coffee and not wanting to get caffeinated to the max. No trouble, though, pulling nice shots with the double basket.
LMWDP#308
LMWDP#308
Oh, the single basket is perfectly usable all right, just as drgary says. Especially if the strength you enjoy is on the Americano/lungo side of the spectrum.
I'm partial to ristrettos, however; going to the 49mm basket makes a small ristretto to start with, but making one with the single basket - well, there's just not a whole lot there in the bottom of the cup. So, while perfectly usable, my single baskets don't see a lot of traffic.
