La Pavoni Europiccola and pressures
Hi to everyone, sorry for this basic question, but there is something about pressure reading that is a little confusing to me.
Why in the Europiccolas the gauges tells that 14 psi-0.9 bar is a normal pressure, while in others machines the gauges read 130psi-9 bar for a normal pressure.
Is a silly question, but with the little technical knowledge i have..such a simple matter is far away for my basic understanding.
Thanks!!!!
Thanks!!!!
- HB
- Admin
You may be confusing steam and brew pressure. For steam boiler pressure, 0.9 to 1.2 bar is common. For brew pressure, around 9 bar is common.
- yakster
The brew pressure comes from a pump, with a lever, you're the pump and your pull will be 6-9 bars.
The boiler pressure will determine the water temps and steam power. Too high and your group may get too hot.
-Chris
LMWDP # 272
LMWDP # 272
Very clear guys!
Thank you very much for the time and the detailed clarification, like always.
Abrazo,
Abrazo,
