Initial Impressions of the Ponte Vecchio Lusso - Page 16
- timo888 (original poster)
Peacecup had urged me to try a three-pull shot a while ago, but my 3-pull shots would blonde early in the third pull. PC and I dose and tamp differently. This morning, in a hurry, I happened to dose all at once from the doser rather than my usual thwack-thwack-thwack-thwack as the beans are being ground (necessity the m-f of invention) and the first pull was more like a rapidly dripping faucet than a flow, an extended preinfusion really, since I hadn't loosened the grind any. So I pulled twice more. A very nice ristretto indeed
I just purchased a Lusso and need to order a tamper. I have seen conflicting information on the size, some say 48mm and others 45mm. This thread seems to agree on 45mm. Could anyone chime in with a definitive answer?
Thanks!
So far the Lusso is way nice, though I am a newbie and am doing some quess work still. This thread has been very helpful.
JP
JP
The inner diameter of the filter basket of the Ponte Vecchio Lusso is 45mm.
Regards
Timo
P.S. Congrats--enjoy the machine.
Regards
Timo
Thanks, Timmo88, that is great help.
I experienced my first blow out this morning after not waiting long enough after a single shot loading in the double basket. YUCK!
JP
JP
- peacecup
I just pulled a great three-pull shot. Probably came in between 30-45 ml. I had been grinding very finely as of late, and tamping rather lightly. My shots were pouring very slowly, often requiring a little lean on the first pull. I just departed from this by grinding a little more coarsely, but dosing right up to the fill line. The shot poured just perfectly, and I was able to get three full pulls without any blonding. The taste was exquisite. It brought me back a little towards my PV roots - when I first got the machine I tended to grind more coarsely and tamp very hard. I gradually went to the finer grind/softer tamp, but this time came back a liitle.
The moral of the story? The little 45 is even more versatile than I previously thought. With the double basket one can pull anywhere between a 30 ml "espresso syrup" ristretto to a 60 ml traditional doppio, each in its own way, the essence of espresso.
PC
PC
LMWDP #049
- prof_stack
That's EXACTLY what happened to me when I demo'd the unit. Joe was all over it.peacecup wrote:I've never noticed any issues with the piston seals getting sticky - perhaps this is because I never activate the lever when the machine is not up to pressure (so water can lubricate the piston). I was VERY clearly told this by Joe at Good Coffee Company the first time I visited there. I grabbed the handle of his brown Sama Export demo machine and was about to test it....
PC
Since he completely reserviced the Export before I bought it, I believed him. And still do.
LMWDP #010
We are trying to reassemble, anyone remember the correct order of the bevels on the three gaskets?
If we could do bevel up on the bottom two it sure would be a lot easier, and we know it matters.
Thanks
Carrie
Thanks
Carrie
LMWDP #104
I got my machine with p-stat tuned to 1.5 bar. I had to re-tune it to 1.15. For those of you who want to do the same without too many iterations, screwing 1/2 cycle (anti clockwise) will do the work
