Initial Impressions of the Ponte Vecchio Lusso - Page 2
- timo888 (original poster)
The water-draw on the Lusso defines the shot, I'd say, more than its basket size, though dosing on the shallower single-basket is unforgiving because of headroom issues. The double basket is much easier to work with. With the Cremina I pull singles almost exclusively-- the Cremina's single basket is quite forgiving in terms of dose. With the Lusso, I have been using the double basket.chopinhauer wrote:I'm wondering if you find the 45mm baskets a bit limiting. I mean, the single must be tiny, and the double must be smaller than the pavoni / cremina doubles, which are only the equivalent of a single on a 58mm machine.
Two pulls on the Lusso using the double basket will yield a 40ml espresso, ± a few ml, depending on the roast depth, age of roast, dose, grind, and preinfusion. I will try some three-pull shots to see what gives, but I am very happy with the quality of the two-pull 40ml espresso.
While waiting for some beans in the mail, I picked up an espresso blend roasted Full City at a local roasterie and coffee shop, where I tried a double with the blend on their Nuova Simonelli commercial machine with its 58mm baskets. The crema was more mousselike on the NS but the Lusso's shot was smoother and sweeter. Some of that difference could be attributed, of course, to differences in temperature, but some is no doubt to be explained by the different pressure profiles. The Lusso does produce a nice "Guinness effect". The Lusso did not fare poorly in that informal comparison, its 45mm baskets notwithstanding.
One can pull godshots on any basket, 45mm, 49mm, 51mm, 53mm, and 58mm.
Apart from price, for me the primary deciding issues would be the kind of lever machine one would like, manual or a spring, and whether a "personal" machine would suffice: is inter-shot temperature stability over more than two or three espressos a requirement?
Regards
Timo
Michael,mgwolf wrote:How do you find the build quality of the Lusso? Everyone always raves about the Cremina and I doubt that the Lusso is of the same caliber. What are your impressions as to how it's bolted together?
The plumbing on the Lusso looks very solid and the boiler materials and fittings seem to be of high quality. The welds look clean. The lever feels very secure and solid. The machine has a low center-of-gravity and does not tip. The portafilter is heavy and solid.
There are some things in the convenience, aesthetics, and fit-and-finish categories that are less than perfect, but they are relatively insignificant in the overall scheme of things:
Regards
Timo
- bill
Timo,
Your review of the Lusso is very interesting and well done. I can't picture ever giving up my commercial Gaggia but if I did have to go with a smaller machine it would be the Lusso.
Re the concern by others of the 'small' 45 mm basket I don't see it as an issue. My first spring-lever machine, La Riviera, used the same group as the Lusso, or at least I think it did. The double basket was deeper then that of a 49 mm Pavoni and the Elektra. I checked it once and found the Riviera's basket to hold more coffee then the Pavoni and essentially the same as the Elektra. All could make great espresso.
Bill
Bill
Bill
LMWDP #43
I wasn't born in Texas, but got here as fast as I could!
LMWDP #43
Bill,bill wrote:Re the concern by others of the 'small' 45 mm basket I don't see it as an issue. My first spring-lever machine, La Riviera, used the same group as the Lusso, or at least I think it did. The double basket was deeper then that of a 49 mm Pavoni and the Elektra. I checked it once and found the Riviera's basket to hold more coffee then the Pavoni and essentially the same as the Elektra. All could make great espresso.
Thanks for the corroboration on the basket issue. I have been dosing the double basket to the rim and using a modified ChicagoChop-Stockfleth combo, with the edge of the stainless spoon handle, and then tamping very very lightly, just enough to level the surface and get 6mm of headroom. It is easy to put the machine into a semi-stall by tamping with too much force.
The Riviera's group does look very similar in shape. I have not seen one in person to know if it is the same size and mass. Did the Riviera have a thermosyphon?
Regards
Timo
- Trisha
The selection of one most knowledgable, objective and certainly the embodiment deservingly considered a home barista must indeed be you, Timo (if Mo had been selected, the girls in the shop would quarrel incessantly, if nothing else; and Karl would see the Lusso showing up with a U-Haul just to get to the wine cellar. . .)!
Awaiting pictures.
This promises to be most enjoyable.
Trisha
Awaiting pictures.
Trisha
LMWDP# 95
. . . and cello sonatas flow through the air. . .
BTW, H-B member grong already posted some good pics of the boiler and p-stat. Maybe they can tide you over till I get my battery.
Now, ain't that a purty boiler
Need frothing tips for my Lusso!
Regards
Timo
P.S. If only I had a U-Haul full of wine to stock my non-existent cellar with. Pennsylvania used to be a terrible place for wine but has made great strides in recent years. The head of the Commonwealth's Liquor Control Board, who recently resigned his post, managed to turn a moribund state-controlled system to consumer advantage. The State's considerable buying power enables it to buy up entire lots and pass the savings on to the consumer, even after the 24% tax.
Unfortunately, there are more bargains at the high end ($75 bottles on sale for $45) than at the low end where I happen to hang out (e.g. $20 bottles on sale for $9).
Regards
Timo
- bill
Timo,
The Riviera group was directly bolted to the boiler; no thermosyphon. It did heat up after a couple pulls.
My Futurmat, a commercial machine, did have a thermosyphon but I can't say it was much of an advantage over the commercial Conti and Gaggia which have groups bolted to the boiler. These machines are built to leave on 24/7 and my guess is they don't heat up due to the huge mass of the group. At least that's my theory.
Bill
Bill
Bill
LMWDP #43
LMWDP #43
My wife thinks I've totally lost it now... more pictures of the espresso machine?
Anyway, I continue to love the Lusso, having been directed to it by this forum, and thought I'd put up some of the requested pix. I have little to compare it with, but friends and neighbors are consistently amazed by the quality of the shots and it steams effortllessly and, as has been mentioned, almost forever. I'm glad Timo likes the 1.1 pressure setting, b/c I don't want to mess with mine. Shots are bigger when you get a little pre-infusion dribble from the extra pressure. A third pull works too, if you overfill the basket to begin with, but it otherwise blondes. I'm growing to love the short, syrupy shots that it seems designed to pull. I used to bring a huge go-cup of coffee with me on my morning 30 minute commute. Now I just toss down a double on my way out the door and can taste it all the way there. Big quality of life improvement, and I'm not spilling hot beverages on myself anymore in the car.
Greetings to everyone here, especially the Sama/PV crowd.
Best,
Will
Gene at Vaneli's threw in an accesory kit that included the 45mm tamper (I bought his Roma grinder at the same time).
I found the single basket to be a very tight fit and very difficult to get out. I also find that I never use it anyway.
Note the SAMA nameplate that Timo mentioned.
Depth of drip tray has been no problem for me. I do a warming flush into a cup, so all it catches are the blonde dribbles at the end of my shots.
Best,
Will
The single basket is deep, and easily holds 7gm. I'm not sure what you mean by a thick and strong espresso, but IMO, the espresso from the PV Export (same group as the Lusso, although I don't think the Export has the thermosyphon) brings out more of the fruit tastes and sweetness, where the espresso from my Brewtus II brings out more of the chocolates, creamy textures, and low-tone flavours. Both cups are balanced at their best. If you are a body and crema junky, I would say that the PV is not your cup. For roundness, smoothness, sweetness, and bell-tone clarity, the PV is outstanding. Expressed as brew ratios, my PV shots range in the 38% to 48% dry/wet ratios using both the single and double baskets, whereas my Brewtus II shots range from 56% to 75% dry/wet (with numbers in the 60's as typical).chopinhauer wrote:Very interesting review timo.
I'm wondering if you find the 45mm baskets a bit limiting. I mean, the single must be tiny, and the double must be smaller than the pavoni / cremina doubles, which are only the equivalent of a single on a 58mm machine. (I had a Silvia with la marzocco baskets and the single LM held the same as the pavoni double, and the pavoni double is the same size as the new cremina double baskets).
You do mention that the 45mm basket is a factor, but how much of a factor for those who like a really thick and strong espresso? In short, how would compare the shots of the lusso double against say the cremina double (using the smaller pavoni sized baskets, not the older and larger cremina baskets, not to mention the even larger Elektra baskets).
I should note that I have only been using my PV Export for a few weeks, and have limited my shots to 6-7gm doses in the single basket and 11-12gm doses in the double.
Mark
LMWDP #106
Nice pics, Willblallik wrote:Anyway, I continue to love the Lusso, having been directed to it by this forum, and thought I'd put up some of the requested pix.
I note the escutcheon-clutter.
Yes, I think it is best to accept the machine with its classic water draw.blallik wrote:A third pull works too, if you overfill the basket to begin with, but it otherwise blondes.
That flat-bottomed tamper works well with the double basket. A convex bottom would work well with the single basket.blallik wrote:Gene at Vaneli's threw in an accesory kit that included the 45mm tamper
The single basket does not sit properly in the portafilter when the clip is in place. The spring clip in the portafilter is, I believe, inserted by Vaneli's and is not original to the machine. Having become quite adept at dumping grounds with the Cremina and Peppina, neither of which use a spring to hold the basket in place, I removed the clip -- it comes out easily and can be easily put back in place.blallik wrote:I found the single basket to be a very tight fit and very difficult to get out. I also find that I never use it anyway.
The depth of the tray is not a problem in terms of the amount of drippage the machine produces, which is minimal. But the tray could be made deeper (and of hard plastic like the 1992 Cremina's, to keep costs down) and have matching half-moon cutouts for the fingers, so it would be just a bit simpler to lift out if one should forget to dump itblallik wrote:Depth of drip tray has been no problem for me. I do a warming flush into a cup, so all it catches are the blonde dribbles at the end of my shots.
Regards
Timo
