How to avoid wet pucks with spring lever?
- TheMadTamper
I'm still adapting to my new Achille, but one semi intermittent annoyance I've been having is some water on the puck unless I wait a good while for all the tripping to cease. If I'm doing back to back Americanos and taking the PF off fairly quickly after a shot, I don't get a real sneeze, so it's not over-pressurized at that point, at most just a slight "pff" but the puck at that point still has a lot of water on it and can get messy if I don't let it sit longer.
That may be all normal, but I figured the pucks would be a bit drier than that, and I'm curious if it comes down to inevitability, if I'm grinding too fine, or if dosing too high/low factors in at all?
It's a trival thing, but I'd rather figure out all the quirks as I go if I can!
LMWDP #642
Grind as fine as you need to get the extraction you are looking for. Sometimes there will be water left over in/on the puck. I suppose it's a function of particle size, tamp pressure, roast level and bean density. What's important is flavour.
when doing back to back shots, even at a real fine grind (think 45-55 sec extractions), I can simply cock the lever slightly to release any (or most) PF pressure. I don't mind that the PF content is still wet, it's a function, you either wait or deal with it.
LMWDP #483
- TheMadTamper (original poster)
Great info! As long as it's normal behavior of the design and not a flaw in technique/process, I'm content!
LMWDP #642
On my machine I pull the lever about 30 degrees with one hand and hold it a couple of seconds then release the PF with the other hand. The is no pressure release and puck is dry.
It's the water. Don't put water in the boiler and you will not have wet pucks.TheMadTamper wrote:. . . one semi intermittent annoyance I've been having is some water on the puck . . ..
-- Richard
That was it! It's all better now, thanks!
LMWDP #642
Sorry, ill advised after a couple hot buttered rums..
- Supporter ❤
Funny you should mention this. My Club never had any appreciable pressure to release. When I started using the Elektra I started with the same grind I used in the Club. Why not, eh? After the second wet puck mess in a row I deduced a change was necessary. It blew grounds all over the place and ruined the drinks. I have family members who like to pull their own shots and I like to keep things super simple & consistent.
At first I tried a slow release of the portafilter. But that didn't work due to what the locals in Idaho would call a "hair trigger."
I've alleviated most of the issue by grinding much coarser, while going up 1g in dose. The taste is still outstanding, and but I may continue to coarsen up the grind to see if I can mostly eliminate the issue to keep it simple. I'm at 15g instead of 14g.
The Club is such a mellow machine - it definitely is doing a lower pressure shot than the Elektra. I could not replicate the Elektra blowup on the Club if I pulled the portafilter off mid pull.
- another_jim
To my mind that's solving a minor problem by creating a major one. Portafilter sneeze just requires a little patience to cure; by grinding coarser, you are compromising shot quality, especially with lighter roasts.jwCrema wrote: ... I deduced a change was necessary. ... I've alleviated most of the issue by grinding much coarser,
Jim Schulman
