Help me with Faemina - video
Hello,
Can you please look at the video of me pulling a shot with Faemina and give me advice? Are these volumes normal and expected? How do you pull a normal 1:2 shot?
I've never actualy measured or worried about the volume of output of my Faemina...it excels at ristretto-ish pulls...no double pulls, nothing.
If anything you may want to try a little longer pre-infusion (15-20sec) and longer pulls (grinding finer).
http://www.youtube.com/watch?v=B3JPixI_wYw (personally have never used the double pull)
There is a way to adjust the volume , I think....the piston assembly is somewhat flexible if I'm not misstaken. You might be able to shorten the distance between the piston and the top of the piston rod. Just need to ensure the piston does not hit the showerscreen when assembling, but you are looking at moving the piston up.
http://www.francescoceccarelli.eu/Faida ... po_eng.htm
LMWDP #483
- yakster
When you pull the lever down slightly, the group begins to fill, continue pulling and the fill hole is closed, but when you pull down the lever further the fill starts again. I see that you are waiting 10 seconds with the lever just barely pulled down, in this position the piston is not fully in the up position so the fill volume will be less. I pull the lever all the way down and then wait for the group to fill, I think you'll get more volume this way.
-Chris
LMWDP # 272
LMWDP # 272
A few notes
I like longer shots and what I do is pull the lever, let it rise while my hand is guiding it until I see drips in cup. I Re pull the lever again and release. The Faemina has a 1-way valve design which doesn't disturb the puck during a Re pull besides the pressure This way, I get about 35g out
http://www.youtube.com/watch?v=zGs_1PjAnRU
Regarding other advice, 0.5 bar is very hot for a Faemina pull. The group head is "saturated" in a sense so I pull at 0.3 bar and i temperature surf by opening the steam wand with the heating elements turned off. Temperature can also affect shot output yield but that doesn't look to be the effect in your video
Cheers. The faemina is a great machine
- yakster
My Faemina was set up for 0.3 Bar for low heat setting by Doug Garrott, I was able to pick mine up refurbed from Orphan Espresso when they were blowing out all their old machines to focus on making grinders. It works well that way. Good to see another Faemina user.
-Chris
LMWDP # 272
LMWDP # 272
Thank you, guys Ill try everything you said and to lover pressure a bit.
the faemina has a clever adjustable spring loaded pressure valve , which is a continuous bleed type. Major drawback of a faemina is that you cannot leave it on as the 1.5L boiler will empty itself.
LMWDP #483
