Help finding piston gaskets for a commercial vintage espresso machine
Hello all,
I own a lever machine dated back from around 1960.
I want to purchase a set of V gaskets for the piston and having some difficulty finding them.
The local company that used to build these machines have no idea where to get the parts anymore.
Sizes are:
Inner diameter is 38mm
Height is 8mm.
I'm attaching some pictures and would appreciate any help!
Sizes are:
Height is 8mm.
Hi,
the spring part and top look a lot like my brugnetti, which happens to be 38mm as well.
It look like it's a pretty standard fit, faema W and V gaskets.
I think those gaskets should fit.
https://www.ersatzteil-handel24.com/vis ... 16_FR.html
https://www.ersatzteil-handel24.com/fae ... 17_FR.html
cheers
fred
cheers
fred
LMWDP #596
- Bluecold
You can probably get away with a normal o ring. I've used normal viton orings in my caravel.
LMWDP #232
Are these two the same? Or do I need a different one for the middle shaft?fredgab wrote: I think those gaskets should fit.
fred
I can't tell if the originals were normal o rings since they're so worn out... but v should do a better job don't they?Bluecold wrote:You can probably get away with a normal o ring. I've used normal viton orings in my caravel.
Two different ones W (or X) for bottom and V for top (not sure about up or down now but could check)maor wrote:Are these two the same? Or do I need a different one for the middle shaft?
I don't think you need 3 gaskets, I have two and a space in between as well. Don't think an O-Ring would work; you need the water filling the gasket to make a proper seal.
fred
LMWDP #596
- Bluecold
Theoretically, orings aren't suitable for the low piston speeds of espresso machines, as you can get spiral failure.maor wrote:I can't tell if the originals were normal o rings since they're so worn out... but v should do a better job don't they?
In practice, I haven't noticed that in two years on my Caravel. I wouldn't hesitate to try some o rings if I would find it difficult to source new seals.
LMWDP #232
Thanks Fred, I think I took the middle one a part when working on it a few years ago. But now I question my memory...fredgab wrote: I don't think you need 3 gaskets, I have two and a space in between as well.
Bluecold, I'll start with the v and if I'll have nothing to lose will go for the o's
Thanks, hope I'll manage to solve this, been lazy long enough with this project!
- drgary
Have you removed them? Can you show photos? Even if they're worn, you can probably see what they were.maor wrote:I can't tell if the originals were normal o rings since they're so worn out... but v should do a better job don't they?
Also I wonder if you have any badge or identifying markings on your machine, or measurements of the cylinder and the piston?
LMWDP#308
LMWDP#308
