Hello Strega !
El_hondero
#1: Post by El_hondero »
So after looking at the profitec pro 800 , quick mill achille and the Bezzera strega for months .
I finally settled with the strega
This is my very first proper machine , before that I was using a moka pot and a picopresso.
I must say I am very impressed by the build quality, I was initially quite concerned about the pump noise , but it's actually quite alright .
The lever is not that easy to pull , Jim schulman's knee bending technique works well !
Ad-85
#2: Post by Ad-85 »
Congrats on the Strega. Looks great! How's the mouthfeel and crema?
LMWDB #691
Aida Batlle: Indigo Reserve from world renowned Finca Kilimanjaro in El Salvador
Sponsored by Aida Batlle
baristainzmking
#3: Post by baristainzmking »
Congratulations, it's a beautiful machine!
Julia
kalo925
#4: Post by kalo925 »
Nice looking set up! What's you cup going to be? I'm looking at some Loveramics cappuccino size (200ml) and maybe grab a couple espresso size too. 8)
El_hondero (original poster)
#5: Post by El_hondero (original poster) »
Ad-85 wrote:Congrats on the Strega. Looks great! How's the mouthfeel and crema?
Package came on the evening, haven't had the time to really dial in the grind yet
#6: Post by El_hondero (original poster) »
kalo925 wrote:Nice looking set up! What's you cup going to be? I'm looking at some Loveramics cappuccino size (200ml) and maybe grab a couple espresso size too. 8)
I think I might get myself some colorful ancaps 160ml cappuccino cups
baldheadracing
#7: Post by baldheadracing »
Congratulations!
The wood really changes the look of the machine. I'm surprised by how much.
Decent Espresso: espresso equipment for serious baristas
Sponsored by Decent Espresso
TomC
#8: Post by TomC »
A belated welcome to HB Jeff! The Strega has incredible capabilities.
Take a gander at the modifications I did on mine, there's several simple tweaks that can insulate your ears from the pumps noise.
The Super Strega: Modifying preinfusion pressures and other functional improvements
BTW, I love that massive wood top/block!
#9: Post by El_hondero (original poster) »
It's just a kitchen island from Ikea :)
#10: Post by El_hondero (original poster) »
Hello I have a question and I hope you guys can help me.
So during the process of dialing in my grind size, I may have ground a bit too find , when I engage the pump , no coffee comes out of the pf, but instead water comes out of this bit
The machine also makes a high pitch noise while discharging water from that bit... This happened maybe 5 times , each time I quickly disengage the pump .
Is this bad for the machine? Have I damaged it ?
Also when the machine is idling or off and cooling down, that bit would drip water (not a lot, maybe drop of water every 5 minutes) I found like a spoonful of water on the drip tray.
Is this normal?
Thanks guys
