Gravity Fed La Pavoni - Just an idea - Page 2
TomC
#11: Post by TomC »
Wow!
Worth the work?
KurtAugust
#12: Post by KurtAugust »
What work? Here a full view of the ugly beast.
LMWDP #325
TomC
#13: Post by TomC »
It looks like Art Neuvuex! :D
My French is horrid, but I look at this picture and think:
C'est ne pas un Pavoni :)
Whale
#14: Post by Whale »
Anyone can say what they will but to me it is now proven that the Europiccola looks good even upside down!
I am glad that you went ahead and gave it a try... I was thinking about it and was just too lazy to do it. :oops:
The only issue, that I can see, with the orientation that could not be easily fixed is the elements. You would have to fill in the boiler every shot or 2 just to keep the element immersed?
LMWDP #330
Be thankful for the small mercies in life.
allon
#15: Post by allon »
What you need is an element that screws into the original full cap port...
LMWDP #331
Chert
Supporter
#16: Post by Chert »
My version of the gravity fed la pavoni was to mount an open "boiler extender" using the threads of the cap with the dipper tube removed or rotated 90 degrees. I sent an email to Barb and Doug months and months ago about the idea and how to get a threaded tank or used Pavoni boiler with connection tube. I did not know what I would have done about the pressure release valve and whether it would leak. That's where that idea ended.
Kurt,
As regards the title of this post - You have made it. It is no longer "Just an idea."
Good one and congratulations!
LMWDP #198
KurtAugust
#17: Post by KurtAugust »
One problem I don't see being solved is that the water inlet is very small for a non-pressurized preinfusion.
If I find a small heating element people use in chemistry classes I'll reinstall the freak.
On that leaking:
Isn't there a cap nut that would fit the pressure valve thread?
LMWDP #325
pacificmanitou
#18: Post by pacificmanitou »
Ive considered something like this before, but I never planned to use the pavoni boiler in any of my designs, just some generic type of kettle with a tap leading to the pavoni group mounted much lower. I dunno, seems to me that it would be easier to build a boiler than try to modify one made for a particular orientation.
LMWDP #366
KurtAugust
#19: Post by KurtAugust »
To continue the cheap ass experiment, I was thinking to pick up something like these:
Dutch: Dompelaar
German: Tauchsieder
What do you people recommend? 300W - 1000W? With 300W, you could add some cheap diimer for control. Just an idea, of course. Who needs pid and god knows what's out there. Glue-on flat elements with buit-in thermostats, any good stuff I don't know about?
LMWDP #325
KurtAugust
#20: Post by KurtAugust »
Francesco Ceccarelli donated some beaten up parts to make a permanent version of this. Thank you!
Except for the group piston, I have everything lined up.
Right now, I'm thinking of an elegant way to plug the holes in the top of the boiler. I mean bottom. Of course, these are not standard metric threads and the hardwares stores only want to order a big box of special nuts. I don't think so...
Any suggestions for a cheap ass leverist? Ideally, the budget is nearly 0.
LMWDP #325
