Flair 58 - Page 47
Yeah ... maybe ... but we have yet to see how it would work. The water poured into cylinder won't passively wait for the temperature to stabilize, it will be evaporating and cooling down, which will in turn trigger the heater. Eventually it may stabilize around wanted temperature, but I'm not sure it will be very precise regulation. Sure, you may cover the cylinder with some cover, which adds an additional item required for this ... so I'm not sure this is the best possible workflow ...renatoa wrote:With the 58x, mandatory buy, imo, you can keep the piston low all the time, so the water don't touch the puck until you raise it.
You can wait indefinitely in that position to stabilize the temperature.
That's good that they made that change. But "mandatory buy" is not the right phrase with a product that is a moving target, at least not for me. I take my time considering purchases like this. I was a potential Flair customer in early 2018 but it wasn't until the following year that I actually bought a machine. What will the flagship Flair look like a year from now?renatoa wrote:With the 58x, mandatory buy, imo, you can keep the piston low all the time, so the water don't touch the puck until you raise it.
Forget anything about the initial 58 version, it is simply bad design, without the valve in piston.
Well... language barrier
I meant atm there is no reason to buy the older 58, with solid piston.
I knew what you meant. I just enjoy complaining about Flair.
Hi. I understand your point that the new version of the Flair 58 is preferable to the original version. What is your view on getting the old one and the upgrade kit? I am asking because here in Australia the new one does not seem to be available yet...
Thanks. They will send the upgrade for free. Is the old 58 with upgrade equivalent to the new one or are there differences?
You can read here the differences:
https://flairespresso.com/product/flair-58x/
Short story: puck screen, new plunger, and more solid frame/lever.
Probably the new plunger only is subject of free update, I guess...
I agree the new model is strongly preferable, but the 58x is the model with no electrical heater and doesn't say anything about the updated design. Both the 58 and 58x got the piston upgrade recently and it doesn't look like they have a new name for it.renatoa wrote:With the 58x, mandatory buy, imo, you can keep the piston low all the time, so the water don't touch the puck until you raise it.
Q: Has anyone done a temperature study on this? From what I've seen from Flair pre-lease videos, it should be very solid, but I would be curious to know if someone did a study with a Scace or something similar, especially for back-to-back shots.
