Flair 58 - Page 3
- Brewzologist
Hoping the base will be designed differently than earlier models to accommodate a variety of different scales.
EDIT: And hoping the design of the new lever mechanism will allow for more ease, smoothness and control for those of us who obsess over our pressure profiles.
Perhaps the piston is electrically heated so that it does not immediately draw the heat from the kettle water? This would overcome the one major drawback of the existing Flair/Robot. It only needs to be heated somewhere between 150-200F, I would think. With this improvement I might think it could rival any electric machine with an experienced user.DaveB wrote:Cord?!?
I'm very intrigued so I joined the Flair FB group over the weekend to find more info. This thing is real apparently -- official reveal later this month and sales (not pre-order) beginning mid-April.
I have to see how it all works in coming weeks, but this seems like a step in the right direction for my ideal espresso machine at home:
- no steamer, no boiler, no pumps and valves ---> We don't drink cappa/lattes. I can boil, pour water, and apply force just fine, thank you.
- electrically heated group so we can dispense with manual preheating rituals which may not even be enough for some light roasts
Early report of max temp numbers sounds great (maybe even slightly too high for most coffees). What is important (to me at least) and unclear is how much temp control we have and how consistent it is. I see three LED lights on the wire thing in the photo so maybe they have some basic adjustment setting and status indicator built in?
"...real apparently..."
[UPDATE: video no longer available]
... if not real then we have a good deep fake case
Looks like also The Lever Magazine has a front facing picture of the new Flair 58
No idea if they also have other pictures as well
https://thelevermag.com
- CarefreeBuzzBuzz
Certainly creative rethinking of how to heat and add water.
- Brewzologist
- I like the handle design in the video, which hopefully will improve the ease of controlling pressure during a pull.
- Will be good to learn how the 3 heater settings work. Would rather have a dial to select a specific temperature and have the group head hold it
- Looks like my scale will fit!
Interesting! Looking forward to seeing people's thoughts once they use it.
It seems Flair decided to make video private... sorry guys, just the messenger ...
- CarefreeBuzzBuzz
For those that missed it, the Flair 58 has a cord with 3 settings for pre heat. In addition, there is a "latch" that connects the handle to a "pressure plate". You disconnect the latch, remove the plate and pour in the water. You then replace the plate and engage the latch, and pull the lever.
For the few that saw it feel free to explain it better.
