Flair 58 rotating plunger valve assembly.
Wasn't sure until Flair added an accessory to deal with the problem that I had a one off issue. The rotating valve. Not sure what actually causes the assembly to slowly, but steady rotate. One thing I have notice is it is in a counter-clockwise direction. Same direction as securing the portafilter. Coincidence? Cause and effect?
The ? Which way does your valve unit rotate?
Anyone know if the still out of stock Flair Plunger Key is fabricated out of plastic or metal?
LMWDP #151
I suspect that it's was related to the portafilter turning, but admittedly I can't say I've thought too much about it -- it happens every once in awhile for me, I twist it back, and all's good. It's to me a small quirk that's an occasional bother, and even then only if I don't adjust it before starting up a shot; and even then, it takes a bit until it it has ever actually caused an issue with a shot.
I can't answer the plunger key question, but personally I've had no issue turning it by hand -- well, other than touching it when heated, which I don't recommend.
LMWDP #699
Hasn't been a real issue with the machine. Guessing maybe couple dozen pulls before it has rotated ~30 degrees.
Sent off an email to Flair today. Received a quick reply from Flair explaining the why?
"The plunger rotates since there is no linkage on the lever to make the drive of the piston linear, the whole system must tilt back and forth to accommodate the angle of force from the fixed lever pivot, and this tilt that the plunger goes through is a lot like a coin on a table. It doesn't just flop back and forth from edge to edge, it ends up rolling around the circumference."
LMWDP #151
my understanding: the rotation is caused by un-evenly distributed forces, including 1) friction forces on the plunger o-ring, and 2) the forces applied to the plunger through the stem.MCal2003 wrote:Wasn't sure until Flair added an accessory to deal with the problem that I had a one off issue. The rotating valve. Not sure what actually causes the assembly to slowly, but steady rotate. One thing I have notice is it is in a counter-clockwise direction. Same direction as securing the portafilter. Coincidence? Cause and effect?
With current design - plunger and stem are separate parts there is no way to stop plunger slow rotation unless the plunger and stem are joined together using a pin or similar design, like Strietman or JanYi.
