Faema Faemina slight glass
I'm in need of replacing/buying a new slight glass to replace my old and foggy current one. Anybody who can make, sell or direct me in the right direction, would greatly be appreciated. Thanks
did you check Francesco? I recall reading something about it being pretty standard glass, perhaps taking the old glass to a company doing window replacements / glass items is enough. Making it should be easy enough
Faemina sight glass replacement
LMWDP #483
What about sanding your existing one. I remember having an old car that had headlights that had foggy headlights - auto supply stores sold a sanding kit that when used, resulted in the glass being almost like new (super high grit, wet sandpaper). It may work...
- redbone
Had one cut couple of years ago. Glass place or watch repair should be able to cut simple round piece with ease.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- nirdvorai
Last time I checked with Francesco about the sight glass, he told me to make a replica at any glass shop. The thickness is 3mm.
- yakster
You could try toothpaste too and see if that helps.
-Chris
LMWDP # 272
LMWDP # 272
- civ
Hello:
https://www.cchobby.com/glass-plate-rou ... 3-mm-10-pc
The one in the page I link to is 3mm thick, 7cm in diameter and has a 2mm hole to hang it from.
Drop them a line to see if they have or can cut a few of the size you need.
Obviously without the hole ... 8^D !
Cheers,
CIV
Here's a link to an outfit that makes round glass plate pieces for ornamental purposes:slassahn wrote: Anybody who can make, sell or ...
Cheers,
CIV
it looks quite clear, try a dremel and some cutting paste followed by a polish?
LMWDP #483
