External Olympia Cremina Pressure Gauge
As I rebuild my Cremina I want to make sure the pressure is correct. I don't need a permanent gauge on the unit, but I do want to ensure the pstat is calibrated properly. It sounds like the pressure gauge that you attach to the end of the steam wand is cheapest.
1. Can anyone tell me where to get one of those?
2. Are there any tricky bits to getting it to work?
I assume just bring machine up to temp/pressure, open the wand to remove false pressure (what even is false pressure?), close it, attach the gauge, and the open want back up to see actual pressure. sound right?
- Supporter ❤
Personally, I feel they're essential to dial in a Cremina. This is the only place I know of to buy one:
https://olympia-kaffeemachinen.ch/
A friend of mine bought one from MIgg in March of this year after borrowing mine for months. The gauge isn't have them on the website, so you'll have to send an e-mail to see if he has any.
There aren't any tricks, you've got the whole process. You do need to release false pressure.
- civ
Hello:
When I got my first LP, a ca. 1969 model, to sove the issue of getting a proper pressure setting and thus the proper brewing temperature (no pressurestat on this LP), I clobbered together one of these with what I had laying around my espresso parts bin:
Quick, DIY, foolproof, very inexpensive, easy to use and then put away for the next time you need it.
Basically, it is nothing but a no-frills 0.0-2.0 bar manometer plus whatever is needed to end up in a short piece of silicone tubing of the size needed to slip over the business end of the steam dispenser tube.
It was, of course, a temporary fix which would soon turn into a much neater ie: more presentable espresso accessory.
But as it happens many times with temporary things, it stayed that way ever since.
It's been more than 12 years and still works like the first time.
Perfect. 8^7
It is ovbiously more convenient to have a manometer with a mount on top instead of the bottom and just one adaptor, but ...
Cheers,
CIV
Indeed ...frew wrote: ... make sure the pressure is correct.
... ensure the pstat is calibrated properly.
... pressure gauge that you attach to the end of the steam wand is cheapest.
Perfect. 8^7
Cheers,
CIV
I have used a fuel line on the steamer with a pressure gauge.
I also have used Cerini's cap, its much easier. They are not always in stock but they are handy and come back in stock periodically, I would call as they are out at the moment for an eta.
https://www.cerinicoffee.com/collection ... dified-cap
- nirdvorai
I second the Cerini cap. Easy as can be. I used it for the first month after I finished the restoration. But once I saw everything works as it should, I switch back to the flower shape cap. IMHO its the most beautiful retro style cap for the Cremina design.
- Supporter ❤
Cerini has been out of the caps for well over a year. His supplier was in Switzerland.forbeskm wrote:I have used a fuel line on the steamer with a pressure gauge.
Agree with CIV. I use a slightly longer 30cm silicon tubing.civ wrote:Hello:
Indeed ...
Perfect. 8^7
Cheers,
CIV
You could get a wider silicon with a hose clamp on the steam wand side.
Mine was tight fit...difficult to take it off when its hot. And need to be subtle as i dont want to overtightened the steam tip when taking the hose off clockwise...or loosen the steam tip when doing taking the hose off counterclockwise.
Good to know. I disappeared from the coffee forum world a bit.jwCrema wrote:Cerini has been out of the caps for well over a year. His supplier was in Switzerland.
I must have picked mine up about six months before that then. Fuel line is always a good fall back, leave the steam tip on, hose clamps, not as prety.
