Early Holiday gift - La PAVONI PROFESSIONAL - Page 3
- drgary
Who was looking at the photography? I'm appreciating your wonderful setup bookended by Monoliths!
LMWDP#308
LMWDP#308
Thanks!
I am enjoying playing with La Pavoni, but hate the three hole steam tip. I absolutely can't make microform with it! Where can I get a single hole one? Is it available in U.S?
Julia
- baldheadracing
Bplus, coffee-sensor, and creativewerk all have single hole tips. Creativewerk is in California
https://www.etsy.com/listing/524972251/ ... steam-wand
(I don't have any of these tips.)
I saw the ones from Bplus, but didn't notice that Creativwerks had it. I have a few items already in the cart that I want to get from him, so will add the steam tip.
Julia
- baldheadracing
Max at Creativewerks was great to deal with when he made handles for my Elektra. He had no issue with making the customizations that I wanted (longer handles for a little more leverage, slight design differences). My Pavoni is finally on its way from Italy - I will probably get Max to make a new lever handle for mine.
- drgary
Also, have you tried modifying your steaming technique for the La Pavoni? I work to half immerse three hole steam tips with my La Pavoni and Olympia Express machines (although a 1st gen La Pavoni is pretty powerful on the Steam setting) and then plunge the tip deeper for the final part. With my commercial lever, I just immerse the steam tip and let 'er rip while keeping the pitcher level to avoid painting the walls. This is not to say that a proper one-hole steam tip can't improve things.
LMWDP#308
LMWDP#308
With the Cremina,baristainzmking wrote:...Why do you prefer robot to Cremina?
(1) I had trouble making double lungos (e.g. brew ratio 30% and volume 3-3.5 fluid ounce). The only way I know how to do this is to use Fellini maneuver. And for me this almost always fractured the puck (with resultant channeling). As we know the Robot's professional portafilter basket is quite deep and easily brews double lungos with volumes 3-3.5 fluid ounce.
(2) One cannot brew triple ristrettos (e.g. brew ratio >60% and bean 19 grams to 23 grams) as Cremina portafilter basket cannot hold that amount of ground beans.
LMWDP #568
I will try your steaming technique while I wait for the single hole tip. Who knows, I my be able to conquer the 3 whole one. Bianca has ruined my steaming. I just put the pitcher on the tray, position the tip and the milk just steams itself!drgary wrote:Also, have you tried modifying your steaming technique for the La Pavoni? I work to half immerse three hole steam tips with my La Pavoni and Olympia Express machines (although a 1st gen La Pavoni is pretty powerful on the Steam setting) and then plunge the tip deeper for the final part. With my commercial lever, I just immerse the steam tip and let 'er rip while keeping the pitcher level to avoid painting the walls. This is not to say that a proper one-hole steam tip can't improve things.
Julia
- drgary
