Does ACS Vostok 1 group finally come true?
- truemagellen
Yes it is coming true with programmable preinfusion and many other unique features that go beyond their ACS Evo line.
No, it can be plumbed or not plumbed, users choice. It will always use the internal tank, so variable preinfusion pressures can be selected from the front panel.bakafish wrote:https://www.instagram.com/p/CkQiBw8q_AE/
Plumb in and out only?
The multigroup models can be plumbed and variable electronic preinfusion works by a different method. I'm not sure if this method could be available as a 3rd choice on the one group?
Thanks Dave. Will the manometer be removed from the grouphead as the screen had shown it?DaveC wrote:No, it can be plumbed or not plumbed, users choice. It will always use the internal tank, so variable preinfusion pressures can be selected from the front panel.
My eyes are bad so the pressure on the screen is harder for me to see. Probably if you asked not to have the manometer on the group, they can do this. The only downside is if the groups are in short supply as they are at the moment, you may have to wait an extra few weeks.
When I was at the factory last week (I am on my holidays believe it or not), they only had 1 lever group in stock and were waiting for more.
A very interesting and attractive new entrant kn the new gen lever market!
For the programmable timer, does it mean that there is a release valve to empty the grouphead once the single lr double option orr the set time is reached in order to end the shot? If so would there be the ability to backflush so as to clean ? The light is a nice addition and the new design definitely is a solid improvement looks wise over the Evo. With the vostok about to be launched,, will the evo be discontinued?
LMWDP #729
There is a release valve based on time or pressure, also normal manual operation.
Yes the group can be backflushed, to clean the vent area, probably 2 or 3 monthly for a home user.
The Evo will continue as it is a smaller machine...but the same inside as the one group Vostok.
