Stephane_Paris wrote:You don't seem to apply such force to put down the lever
Interesting
For those interested in how this is possible, the lever on this group provides a 15x1 mechanical advantage and it is pushing a 50mm diameter piston. The lever is 280mm long to point where I press. I can't remember the proper formula. Anybody else remember?
I do know that I can press hard enough blow past the group seal (tested usubg water and a scace-like orifice).
Curtis
LMWDP #551
With a 50mm diameter you need to apply 45 pounds for each bar of pressure. A 15:1 advantage reduces that to 3 pounds per bar. My manual lever, a Robot, requires about twice as much force.
jpender wrote:With a 50mm diameter you need to apply 45 pounds for each bar of pressure. A 15:1 advantage reduces that to 3 pounds per bar. My manual lever, a Robot, requires about twice as much force.
If you can blow past the seal with just hand pressure your seal is compromised. A seal such as that should hold 100 bars without breaking a sweat. Any hydraulic bottle jack also has a thin ring holding the pressure in, and those need to hold in much much more pressure.
LMWDP #232
Bluecold wrote:If you can blow past the seal with just hand pressure your seal is compromised. A seal such as that should hold 100 bars without breaking a sweat. Any hydraulic bottle jack also has a thin ring holding the pressure in, and those need to hold in much much more pressure.
who said it was just hand pressure? I was curious how far I could take the pressure so I locked my arms/chest and leaned a significant amount of my body weight into it.
but you may be right that my gasket could be in need of replacing.
Curtis
LMWDP #551
Unfortunately, we are under extreme pressure now but sometimes in the coming weeks/months we will most definitely mod our first prototype yoke and a fork to see how it works. I like this group head a lot and it will be fun to get to know it even better.
