Damaged La Pavoni
Hello,
Today I received my very first La Pavoni machine and it appears it was damaged in transit. Somehow the tube that brings in the water bent the threads of the group, so consequently it is impossible to put back on. I've only found one site that sells replacement groups and it's pretty much the same price I paid for the machine. Is there any other way I can resolve this problem?
The sender is filing a claim with UPS after the weekend and I filed a claim with eBay.
Thanks
Thanks
- drgary
Filing a claim with eBay should get you a refund, especially if you've fully documented it, showing a photo of the package and the damage. What you received is not what was advertised. Whether or not UPS pays is secondary to your eBay buyer protection.
Perhaps you can post a photo of the damage here so we can see what you're describing.
LMWDP#308
LMWDP#308
- dominico
Do you need an entire replacement group or just the dipper tube?
The dipper tube itself cost only about 7 euro and can be found here:
https://www.lamacchinadelcaffe.com/rica ... avoni.html part# 326002
https://bit.ly/3N1bhPR
- drgary
Is that a third generation group (post 2000)? If so you might be able to file back the part that obstructs threading in the plastic insert, replace the insert if it's damaged, and it should work, since there seem to be enough additional threads remaining, and the group fastens against the boiler. For good measure you could add some thread sealant that isn't a thread locker.
LMWDP#308
LMWDP#308
It is. It's the 2005 special edition model. After I hear back from the seller and see how the claim goes, I'll try to file it down and do that. Until then I guess I'll clean it very thoroughly because she's a bit dirty.
Was the machine shipped disassembled? It's hard to imagine how that dent can occur during shipping otherwise.
Winston
Yes, the machine was disassembled for shipment.
That ding can be easily removed with proper tooling and machine setup. It will be lower cost than a new group.
- erics
- Supporter ★
Perhaps this will help: https://www.google.com/search?sourceid= ... Fs_x9LprlM
Someone with this vintage Pavoni should be able to give you the thread pitch, maybe 1.00 mm?
