Dalton's law (And problems from it) - Page 3
rpavlis wrote:As a retired University chemistry professor, I hope it is in my power to provide some help understanding some problems that arise using machines such as the Europiccola and the like.
Around 1800 a man by the name of John Dalton stated his law of partial pressures. It says that when gases are mixed, the total pressure is equal to the sum of the partial pressures of each gas. Another principle of gas behaviour is the ideal gas law, PV=nRT. Modern students seem to call it "puvnert". P is pressure, V volume, n the number of moles, R a constant, and T the temperature in Kelvins. Still another is the principle of vapour pressure. Molecules in liquids and solids are held together by intermolecular forces of widely differing strength depending on molecular structure. Kelvin temperature is a linear measure of average molecular translational energy. Vapour pressure results from molecules in liquids (and sometimes solids) having sufficient energy to escape the intermolecular forces.
When we turn start a lever espresso machine it is a closed system. The space above the liquid is filled with air and a small amount of water vapour. Atmospheric pressure is usually around 100 kpa or 1 bar. The vapour pressure of water at room temperature is about 3 kpa. Inside the reservoir the air pressure is about 97 kpa and the water pressure is the vapour pressure, 3 kpa.
When we turn on the heat the temperature rises. The partial pressure of the air will raise by PV=nRT, and the water pressure will rise as its vapour pressure rises. Some of the air, however, is forced by the rising pressure into the upper part of the group above the piston which remains fairly cool because this air does not exchange with the reservoir. On machines with pressurestats the heating element is shut off when the total pressure inside reaches about 200 kpa. The air pressure at this point is a bit over 100 kpa and the water vapour pressure is a bit under. This results in a boiler temperature of around 100C. The group is not heated much, because the water vapour diffuses very slowly through the small passage to it. Some call the air pressure false pressure. Actually there is NOTHING false about this air pressure! We must get rid of this air, so we open the steam valve. Most of the air is quickly swept out.
If we touch the group at this point it is only slightly warm. While the air is being released we also need to raise the group lever about 3/4 of the way a couple of times to purge it of air too. It almost instantly becomes hot to the touch, hot enough to burn one's fingers. With the air gone the only gas in the system is now water vapour. The pressurestat turns off when the water vapour pressure reaches about 200kpa, around 120C.
Now we raise the lever and allow a few mL of water to pass through. The top of the group is already at 120 degrees, kept there by steam constantly condensing to keep it there. This heats the bottom. Now we put our filter basket in the portafilter and raise the handle. Air rushes through the porous coffee into the space below the portafilter. When we get the handle clear to the top the opening to the water inlet is exposed and very hot water enters inside the piston skirt. Some of it vaporises and mixes with the air--Mr. Dalton is at it again. There is a burst of pressure which forces much of the air downward through the coffee again, along with a lot of water vapour. As long as the coffee is not flooded with liquid water gases pass through it, and air is lost from the system. Once the coffee floods water is so viscous that the remaining air is trapped. If the piston skirt or cylinder wall be too cold not enough air will leave before this occurs and the pull will be spongy.
When we pull the handle down the pressure increases to about 1000 kpa. The vapour pressure of water is about 90 kpa at the 95 or so degrees of the waer, so 910 kPa is air. Gases are much more soluble at high pressure. Some of this high pressure air dissolves in the water. The high pressure also forces the water through the coffee. As it passes through the dissolved air forms bubbles as the pressure falls and air solubility decreases. This air interacting with surface active materials in the coffee form the foam which we call crema!
What?? Cripes man! Here am I thinking making a cappa outa the lever in the morning was one of life's simple pleasures. Now every time I look at the damn thing my eyes will bleed .
"24 hours in a day, 24 beers in a case. Coincidence? I don't think so."
- KurtAugust
Thank you for explaining the technique to get the head up to temp quickly. It's much quicker than a straight flush. My technique has improved and I lose less water.
LMWDP #325
- mtn hack
Ok. I too have a machine sans vacuum breaker (Gaggia Achille), but I also have to release the "false pressure" every time I restart the instrument. I get the concept of the creation of a vacuum due to the cooling when it is turned off for the night. However, because I do always have the false pressure to release on start-up, I would assume that the steam wand or sight glass/pressure gauge is allowing outside air into the boiler system in an attempt to equilibrate to atmospheric pressure. Can this be entirely explained by cooling fittings and orings allowing small amounts of air to be sucked back into the system, versus when hot, and at greater positive pressures, nothing can escape out?jonny wrote:Nice post. I'd like to add something slightly different but related all the same that might be of interest as well. I have a machine without a vacuum breaker. Every morning I would experience a phenomenon in which shortly after the power switch was flipped, a disturbing explosive sound come from the machine. The whole thing sounded like it was trembling on the brink of eruption. It startled me several times, especially since I built it myself! I learned though that opening the steam wand would halt the sound immediately. I was puzzled and never did find an answer despite lots of HB and google searches. Not until chemistry 222 this past term did I finally discover what was happening. Eureka! Here is the low down.
1. Open the boiler cap, fill with water. Replace the cap. At this point I have filled the boiler with water but also air from the room entered to fill the space above the water. simple.
2. Turn on the machine to begin heating. When the pressurestat reads it's max set pressure, it switches off. However, this pressure is created by the air in the boiler from the start plus some vapor from the heated water. The sum of the pressure from the water vapor and air equal the total pressure. The pstat doesn't know the difference, pressure is pressure. This is "false" pressure as we know it. Proper pressure, improper temperature. It should be called false temperature.
3. The steam wand is opened which expells the air which drops the boiler pressure and allows it to continue heating to full pressure with a saturated headspace of water vapor. Once the pstat clicks off again, the machine is "ready"
4. When coffee is had, and evening is nearing, the machine gets turned off. The boiler cools and the water vapor present in the headspace returns back to the water, now at room temperature.
The twist happens here! The headspace in the boiler is left utterly empty! It used to be occupied by water vapor but now that that is gone, nothing exists there. No air to fill the void because the boiler is sealed. This here is a vacuum!
Here is the kicker, in a vacuum, or near vacuum, water boils at drastically lower temperatures (why our blood boils in space). Once all of this hit me I knew exactly what was happening. When the heating element kicks on in the water at this low pressure, it almost instantly causes the water to rapidly boil which was the cause of all the disturbance. After I realized this, I let the machine do this and continue to heat to full pressure. The noise slowly diminished over the entire duration of heating and when the element clicked off, the machine was at full pressure and temperature, no bleeding of air because there was none! but that noise sure was not pleasant. Anyone who has a machine with no vacuum breaker may experience the same occurence.
I still get the violent (and nearly immediate) boiling upon start-up, which I always assumed was the water near the surface and on the heating element vaporizing. Under your assumptions, the rumbling indicates that the system is still under a vacuum, but if that were the case, should I still have to release false pressure to get the system to the correct boiler T/P ? Is it possible that it is under a partial vacuum, but I still have to release some false pressure to get to the proper operating ranges?
If this truly is what is happening, 3 readings should clear it up.
1)Control: Turn off the machine, cool to RT, release all pressure in the boiler. Warm back up until the Pstat shuts off the heating element, and measure the boiler's water temperature before the release of false pressure and P/T coming up to the proper operating ranges.
2)Partial Vacuum: Turn off the machine, cool to RT and allow the closed system time (overnight) to either stay at full vacuum or slightly rise via atmospheric air leaching into the "closed" system. Turn on, allow to heat until the Pstat stops, measure the boiler's water temperature.
3)Full Vacuum: Turn off machine, allow only enough time to cool to RT, then return to Pstat cutoff, measure boiler water temperature, and see if there is any false pressure to release.
LMWDP #364
