Conti Prestina Dosing Suggestions
Tillamook
#1: Post by Tillamook »
I am in the experimental stages with my new to me Conti Prestina. Everything including the spring is new and working perfectly. It is also maintaining very stable temperature. I have MANY different sizes of 58mm portafilter baskets for this machine.
I am looking for input from others who have this same group, and what they have found to be the sweet spot for dosing, and with which basket? I know I can eventually figure this out on my own, but I will go through ALOT of coffee to get there. Any help is appreciated
drgary
#2: Post by drgary »
My standard dose is 18 gm. Let us know how it works for you!
LMWDP#308
mikel
#3: Post by mikel »
Similar to Dr Gary,18 grams. I use a IMS 20 gram basket.
Paolo
#4: Post by Paolo »
Does your Prestina have the standard 5Bar spring or the 9Bar spring?
I use 20 gms in an HQ double basket with great success.
drgary
#5: Post by drgary »
And of course I vary dose, grind and temperature for different coffees. I once measured my spring pressure to start at 8 bar. My spring was a replacement installed when I restored my Prestina and I only use it occasionally.
LMWDP#308
Tillamook (original poster)
#6: Post by Tillamook (original poster) »
Thank you all for the tips. I have tried various doses with different baskets after reading Dr Garys Prestina User Experiences post. Surprisingly I had not done 18 grams doses yet. I share the same conclusion that none of these experimental shots were undrinkable. Today after reading the recommendations of 18 grams, I tried it for the first time. I accidentally ground a little tighter than normal, but WOW it was almost perfect in taste. I dont want to speak too soon, but all I will say is if I can repeat it exactly the same, I could live with this shot happily ever after.
