Construction of a Bosco Sorrento - Page 9
- IamOiman (original poster)
While looking at plumbed in methods for the Bosco, I noticed on their website that they have an 'Automatic boiler fill and water level control.' Does this mean the machine already has a rotary pump or would it simply help whatever method you attach to the 3/8" inlet whether it's something like a Flojet or attached rotary pump. Looking into similar machines like the Izzo Pompei I see they specifically mention it includes a rotary pump for boiler fill, so it may be this is a new feature for Bosco and I may not even need an external water pump! Any thoughts?
-Ryan
-Ryan
-Ryan
LMWDP #612
LMWDP #612
- JohnB.
It has a control box that opens a solenoid valve when the boiler needs water. The boiler fills at line pressure; no pump. It also has a manual fill valve which comes in handy. When I want to refresh the boiler water I wait for the machine to shut down (6pm), draw out a couple liters of water before the boiler pressure starts to fall & refill using the manual valve. If the control box fails at some point & it's not just a capacitor or relay I'll just remove the auto fill parts & go with the manual valve.
Did you have Bosco install a boiler drain valve?
LMWDP 267
Nope! Drain valves are standard now and I did not need to specifically request one.JohnB. wrote: Did you have Bosco install a boiler drain valve?
So I can actually manually fill the machine if I wanted to?
-Ryan
-Ryan
LMWDP #612
LMWDP #612
- Balthazar_B
Nice. You saved a few euros.IamOiman wrote:Nope! Drain valves are standard now and I did not need to specifically request one.
You can, but it's a bit of a PITA, since you need to remove the drain trays. Letting autofill do its thing is a lot easier. As a matter of (OCD) habit, I glance at the water level window every morning to confirm nothing has gone sideways with the fill valve.So I can actually manually fill the machine if I wanted to?
- John
LMWDP # 577
LMWDP # 577
Where exactly would I even insert the water on the machine when you remove the tray? Also, is the boiler drain activated by pulling the black knob on the front of the machine?Balthazar_B wrote:You can, but it's a bit of a PITA, since you need to remove the drain trays. Letting autofill do its thing is a lot easier. As a matter of (OCD) habit, I glance at the water level window every morning to confirm nothing has gone sideways with the fill valve.
-Ryan
LMWDP #612
LMWDP #612
- Balthazar_B
Ah, right you are. Sunday caffeine hadn't kicked in yet, and for some reason I was thinking of the valve under the driptray. I've used the manual fill exactly once, 18 months ago when I got my machine installed and was priming the boiler. That fill knob has become invisible to my perception.
- John
LMWDP # 577
LMWDP # 577
- JohnB.
Why would you need to remove the drain tray to use manual fill?? The knob is right in front & the sight glass is in plain sight. Couldn't be easier. Pull the knob out until it reaches max on the glass.Balthazar_B wrote:
LMWDP 267
- JohnB.
That's a recent change. I believe David had to specify the drain valve as an option. Have you unpacked & looked at your machine yet??IamOiman wrote:Nope! Drain valves are standard now and I did not need to specifically request one.
-Ryan
LMWDP 267
I have not opened my crate (and will unfortunately not until next year!!), though I am partially basing this (I was told by Roberta they do this as well) by this photo sent by Roberta, which has a pipe that goes to the drip tray from the boiler
-Ryan
LMWDP #612
LMWDP #612
- JohnB.
That would be the manual fill pipe, not a drain. David may have a photo of his drain valve.
LMWDP 267
