Caravel Question
When lifting the lever all the way to the top without portafilter in place, should water come immediately out of the group?
- redbone
Short answer yes.
Water will also leak with portafilter in if held tight up for an extended period of time, where the lever handle connects.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Thank you for answering my question! It was not until after I posted that I noticed the huge Caravel thread. Started reading that one and once I saw how the thing was put together I removed the piston and by its design could see that indeed water would pass through when lifting the handle.
