Cafelat Silicone Lever Gaskets - How Long Do They Last?
Installed mine about 8 months ago. Was literally just thinking my machine is bullet proof. Pulled a shot and the lever returned to resting position. A few seconds later....the dripping began!
When it cools I'm going to pull the piston, but it appears they may have failed!
Machine is a Pro 800 which sees 2 double shots per day.
Anyone experience this?
Update: Pulled the piston and the seals/gaskets look ok. Maybe needed more lubricant, so I removed them all, cleaned and re-lubed. Everything seems ok now. These are the original red Cafelat piston seals, which I know were revised and are now blue (not sure if that may be part of the issue?).
- dpiette
you can't win,
you can't break even,
you have to play.
-the three laws of thermodynamics
you have to play.
