Cafelat Robot User Experience - Page 65
That's what I've been doing! Works amazingly and doesn't really add any time to the workflow.
Loving my Robot! Was my first espresso "machine" and can't say it was too difficult to get good tasting shots once I upgraded my grinder (Encore -> Mignon). Now to start saving for a semi-automatic
Looks a kind of similar to my Flair preheat method.
Eventually, people find out that steam preheating is the way to go ....
I think my pressure gauge tube is near to the end of its life...I realised a bit late that the sharpish edge of the Robot's body was cutting into it (now protected with tape).
I know Paul is on the case with the auromored cable...but not sure I will be able to wait!
Can somebody conform the ID/OD of the tube?
I can measure of course but don't want to take it apart until I really need to.
Thanks in advance.
Thanks in advance.
Have you checked the package that the robot came in? Mine came with an extra tube supplied (along with plugs etc. I assume to disconnect the gauge if required)mcrmfc wrote:I think my pressure gauge tube is near to the end of its life...I realised a bit late that the sharpish edge of the Robot's body was cutting into it (now protected with tape).
Thanks in advance.
Afraid I don't have a gauge to measure the tubing so I'll let somebody else comment.
- Jake_G
LMWDP #704
Thanks yep had seen that but it only mentions 2mm and I wasn't sure if that was ID or OD...guess it must be ID!
According to the user manual, it's 4mm OD tubing, which was also confirmed by my caliper measurement.mcrmfc wrote:Thanks yep had seen that but it only mentions 2mm and I wasn't sure if that was ID or OD...guess it must be ID!
Cafelat Robot User Manual wrote:The hydraulic connection to the piston is then made with a 4mm OD FDA approved tube made by Parker Legris.
Always read the instructions....have learned my lesson!!samuellaw178 wrote:According to the user manual, it's 4mm OD tubing, which was also confirmed by my caliper measurement.
Thanks so much Sam.
Nick, visually probably one of the best shot I have seen from the Robot. I understand you used light roast, how many grams? Did you grind it with kunu M47?chsreason37 wrote:Not sure if anyone with a Bonavita kettle has discovered this, but the portafilter with the basket will balance pretty well in the opening where the lid goes (resting on one of the little pieces that stick out to ultimately lock into the body/piston chamber). I leave it there (with the lid loosely on top of that) while the electric kettle is heating and I'm grinding and whatnot. Makes it really easy to pre-heat and then I don't even have to do the double fill or overfill method for light roasts. Highly recommended.
Really enjoying the Robot I got over the holidays:
<image>
