Cafelat Robot User Experience - Page 513
vit
#5121: Post by vit »
Well, based on various measurements on Robot and Flair classic, maximum achievable brew temperature around sea level is 92-93°C (for Robot, this includes preheating the piston as well). Several other manual espresso machines without own heater can't achieve even that. At 5000 ft water boils around 95°C, so it will be 87-88°C. That's what numbers say ...
Will it be enough for you or not, depends on several things ...
Miltonedgebert
#5122: Post by Miltonedgebert »
The blind shaker thread got me to experiment, and found a way to simplify my prep.
Put grounds in basket
Cover basket with palm and shake vertically 3-5 times
Tap/shake to rough level
Press metal screen down with thumbs
This has proved slightly more even than wdt, and takes less time.
sympa
#5123: Post by sympa »
This morning I poured the beans into a running grinder ("hot start") and shook the grounds. The result in the cup was spectacular. A huge jump in terms of flavor, without any addition of unpleasant notes. Really hit me in the face in a great way. I'm wondering now if this is a one-off god shot or something repeatable!
MountC
#5124: Post by MountC »
So it kind of sounds like an automatic is worth the money over a manual when at altitude.
ende42
#5125: Post by ende42 »
It's more a "actively heated" vs. "kettle driven" than a "manual" vs. "automatic" I think.
What I wonder ... @MountC said "taste is OK, americano got cool qickly". I can't imagine an americano being cold after pouring boiling water on an espresso. I'd say: try preheating the cup and adding boiling water as a first measure.
robotuser
#5126: Post by robotuser »
Miltonedgebert wrote:The blind shaker thread got me to experiment, and found a way to simplify my prep.
Thanks for sharing. In the vertical shaking step do you get grounds stuck with your palm?
SchallUndRausch
#5127: Post by SchallUndRausch »
As I love wooden parts, I made myself a new base that also gives me more space for cups
jpender
#5128: Post by jpender »
vit wrote:Well, based on various measurements on Robot and Flair classic, maximum achievable brew temperature around sea level is 92-93°C (for Robot, this includes preheating the piston as well).
I think that a claim like that has to be qualified in terms of the preheating methods used. Because it is certainly possible to achieve higher temperatures if, for example, you used a flame thrower. I'm being silly but not entirely. I experimented with preheating the portafilter by placing it directly over the flame of my stove. Not surprisingly that was significantly more effective than using boiling water or steam.
jpender
#5129: Post by jpender »
SchallUndRausch wrote:As I love wooden parts, I made myself a new base that also gives me more space for cups
Beautiful work. How much clearance do you have from the top of your scale to the base of the Robot body?
Miltonedgebert
#5130: Post by Miltonedgebert »
robotuser wrote:Thanks for sharing. In the vertical shaking step do you get grounds stuck with your palm?
Maybe a little. It hasn't been enough for me to notice. If I did, I probably just brushed it off into the sink.
