Cafelat Robot User Experience - Page 473
- drgary (original poster)
Put a paper filter at the bottom of your regular basket and wet it before filling with coffee. Let us know if that works.
LMWDP#308
LMWDP#308
- yakster
When I got the Kickstarter it was a choice of either the pressurized or regular. I later bought the pressurized basket when I accidentally bought pre-ground. I could loan it to you.jedovaty wrote:For those of you who have purchased recently from the cafelat store, did your order include both the bottomless basket and the pressurized basket? I am looking through my box and can't find the pressurized basket, though I swear I saw it when I first received mine last month. I did see the canadian retailer offers an option between the two, so maybe the o.g. store has started doing the same. Although.. I have a sneaky suspicious I may have accidentally thrown it out? Hope not![]()
- asking because I actually have an unexpected use for the pressurized basket now, whoopsie!
-Chris
LMWDP # 272
LMWDP # 272
From the Cafelat Store website:
https://www.cafelatstore.com/products/r ... dercoatingInside the box (for orders placed after July 2020)
The main body of the Robot with the arms and base assembled.
Full set of pressure gauge installed (if you have the Barista version)
1 portafilter and 1 portafilter spout
1 professional basket
1 tamper of your choice (original or adding US$50 to exchange the original tamper to a levelling tamper)
1 stainless steel filter screen
1 bag of filter paper as a replacement of filter screen
1 silicone mat
Piston blanking plug and Teflon washer (if you have the Barista version)
- bringyoutomyhell
No pressurized basket for me a couple years ago, I think you now always have to buy it separately
interesting. Do you mean to stop the donut extractions?drgary wrote:Put a paper filter at the bottom of your regular basket and wet it before filling with coffee. Let us know if that works.
in https://coffeeadastra.com/2022/07/16/mo ... tractions/, adding a paper filter worked for him to have a more even extraction, so this added resistance might help for the donuts too
I will test it!
I've come across multiple threads on this forum about the paper, and just be aware, depending on which paper you use, it may increase or decrease the actual flow, so you'll have to taste and compensate accordingly. When I tried it, there was no discernable difference in flow or taste.
You can always buy another basket. Prima has them for $35. They were $25 about 4-5 months ago when I almost bought one.
Maybe a paper filter won't do the trick but if you are handy you might try limiting the flow by blocking some of the holes of the regular basket. A little cutout donut of aluminum foil might work. It would be easy to try.
I also think you could easily add filter paper until flow is impeded, and I'm not writing about donut holes. I also like jpender's idea of creating an aluminum foil ring within the basket.
LMWDP#308
LMWDP#308
