agree with him and others its overrated and not what its about so I do not TRY to get crema I try to get the proper time to extraction amount and it just happens depending on beans more or less
for most things hoff is good for the amount of water thing for the robot he is WAY off and wrong IMHO so just fill near to top
I extract 21 grams 1:2 and have measured some lungo style shots into about 60 grams of water as mentioned so depending on how much you want each drink to have on the espresso end
I wish I got a second basket BUT its not needed as you can just pre grind your next shot dump wipe tamp like any regular machine if you are going to pull a bunch
the first vid dude looks like he is more using that look over the method to see his gauge on the backside mount ? but I could be wrong but looks like that to me
the second vid ? I am not sure I agree on his view ? will leave it at no comment hahahahah
as far as puck lift ? that second video guy had mentioned that in one of his vids which drew some HUH from many here as I remember ? I know I was like HUH
yeah you can get some if you truly lift the handles a lot and quick but you have to try IMHO
so doing any normal continuous or slow ramp up etc. never ever had that issue
I can say I found preheating the piston did nothing for me and taste and a couple times was worse I think a lot has to do with the water being off boil when it goes in vs a set temp lower BUT I say try it make notes find what works for you but do not think you HAVE to do all those steps ! its all personal
also I found one fill in the porta then dump that to be enough preheat ritual and doing more again for me and my beans did nothing in the cup
I fill my cup then my basket twice the second one being the one I lock in then let go the handles so they are just sitting on the pressure they are at (almost nothing I reckon) dump my cup of hot water and place it under then start the pre infusion and pull
I also use a paper filter on top of the puck so from top down its screen filter coffee
I do this for super easy clean up AND biggest reason is I do not have to be slow and careful when pouring in the water
there has been talk of the ring thing on some folks ? again I think this is the nerd side of many here having fun and wondering why I only get that ring now I noticed once in a while with my mazzer never with my comandante ? its pretty even as its showing up
I also only shake the basket no WDT and I use the tamper he created to make a flatter tamp that has the two levels
