Cafelat Robot User Experience - Page 267
Thanks to a jeweler's file and polishing wheel it's all good! whewojaw wrote:Oh no, I dropped my regular tamper onto the portafilter!
Dents in portafilter not a problem, but the tamper has 3 points where the damage makes it scrape against the interior of the basket. I'll try and file/polish it back, but my question is: Paul, are the regular tampers still available? I'm in Canada.
That's what I was expecting. But I couldn't help but wonder if one could remove the top of the new leveling tamper and revert to the original.
Probably could be removed but since the original is good enough for me I was hoping that if it needed to be replaced the original would be cheaper. Like me.
https://www.cafelatstore.com/products/r ... ing-tamper
Yup, it can, though handle would have to be bodged - would likely just 'deal' with the tamper as is.
Oh, I see. I thought the new tamper was just the old one with an attachment. You'd have to make a handle yourself. Bodged... I guess that means you're Australian.
nope, Canadian, but I do hang out on LFGSS.jpender wrote: Bodged... I guess that means you're Australian.
With the slow rampup in pressure (5s), I'm finding I get less chance of channeling (more consistent) and less drop in resistance towards the end of the shot.
What I think is happening is that the gradual increase compresses the puck without disturbing it as much. I get more extraction and less acidity. I'm finding this on med-dark roasts, using a Niche Zero and a firm tamp. It's delicious and sweet, with great clarity.
Agreed! I've found that skipping PI or ramping up pressure too quickly almost always leads to a worse extraction. I typically PI at 2bar for 10s and I get very even coverage of the shower screen and maybe 2 drips into the cup.
My understanding of why the resistance seems lessened by a gentle PI is this: If you ramp up too quickly, the pressure creates a "seal" between the water and the coffee that resists flow. You can easily choke a shot dialed in for PI if you rush through it. Conversely, a gentle PI allows the water to permeate the entire puck before compression starts to seal off many of the water pathways. If there are many open pathways, the likelihood of one becoming a large channel is lessened significantly. And as we know fewer channels means a more even extraction means better coffee.
I've owned the Robot for a little less than a year now, and although I deployed many different methods, I could never really fine tune things to get the taste to something ideal. Lately, I've discovered a method of brewing on the Robot that have yielded the most fantastic results I've ever had, and I'm finally content with what I get in my morning cup.
It involves a paper filter. No, not the default round ones that come with the Robot. With the pandemic I had trouble getting my hands on them. So I used someone's advice in this thread to go to the supermarket and just buy any generic #4 coffee filter and cut them to shape using the tamper as a guide. I tried this at first, but I didn't really notice much improvement in my subjective taste.
Like a lot of anecdotal reports in this thread, my extractions almost always start at the edge, so I've always been suspicious of side channeling as the source of my woes. I believe my side channeling was so severe that, it completely avoids the middle puck for most of the extraction, running only against a side wall. I've spent months trying different WDT methods, different grinds, different dose, I could never solve it.
One day I had the idea to cut the paper filter into an oversized circle (several millimeters in diameter wider) so that when I place it under the screen (above the tamped puck), and push down with my thumb with some effort, there is noticeable paper filter sticking up and out from below the screen, ideally around the entire circumference of the screen. The idea is that, with paper squeezed between the basket wall and screen edge, securing around the entire perimeter, pressurized water is less likely to escape these paths of least resistance. It's a bit tricky to get into place, which just speaks volumes about how precise the engineering is. Nevertheless, when all of this is in place and I brew with no other variables changed, I get dramatically better results, the type that I'd always hoped for when I decided to make espresso at home.
Anyway, thanks for coming to my ted talk. Anyone who has had difficulty with their Robot, especially if side channeling is suspect, I recommend giving my method a shot! It's cheap and only adds several seconds to my morning ritual. I cut these circles in bulk while I'm watching the NBA or something. I'm not sure why it is that I need to do this to use my Robot as it was intended out of the box, but I'm glad I found an easy fix. I thought my screen would be a bit warped, thus side channeling, but it's perfectly aligned as if new from visual inspection.
:-)RyanLovesCoffee wrote:Anyway, thanks for coming to my ted talk.
So your thinking is that it's water passing around the edge of the screen that causes the donut-like start. I've wondered the same thing and thought about adding some sort of gasket to make a tighter fit for the screen. For me the issue has almost entirely gone away with changes to my routine so I haven't tried it.
If you're right then a paper filter that has a big hole in the middle should work as well for you.
Actually no. I never get the donuts that many people speak of. My channeling occurs disproportionately against one side wall, so extraction starts at one edge, then eventually spreads all the way across the entire bottom floor. I actually have no way of knowing what's going on inside, just pure speculation.jpender wrote::-)
You're a genius. I'm going to try your big hole paper method and see what happens!
