Cafelat Robot User Experience - Page 193
baristainzmking
#1921: Post by baristainzmking »
I have to say that the robot is the most forgiving espresso machine I have ever used, bar none! I just can't pull a bad shot!! :wink:
Julia
cooperpwc
#1922: Post by cooperpwc »
Here is an interesting article. It provides some support for the excellent results we get from the Robot at lower pressures:
https://www.smh.com.au/national/interna ... JA_qfIgkRg
ECM Manufacture: @ecmespresso #weliveespresso
Sponsored by ECM Manufacture
GregoryJ
#1923: Post by GregoryJ » replying to cooperpwc »
They're advocating for a 15 second shot, which is not what I aim for with the Robot.
cooperpwc
#1924: Post by cooperpwc » replying to GregoryJ »
I am not suggesting slavish adherence. Think of it as an interesting data point.
even-glass
#1925: Post by even-glass »
doug wrote:I perceive a fellow combination engineer / coffee artist.
:) We all have our flaws.
superdudeo
#1926: Post by superdudeo »
What is the going consensus on tamp pressure with the robot? I think in the manual it says only a gentle tamp is required?
baristainzmking
#1927: Post by baristainzmking »
I do a really gentle tamp and done.
Julia
Flair Espresso: handcrafted espresso. cafe-quality shots, anytime, anywhere
Sponsored by Flair Espresso
jpender
#1928: Post by jpender »
I haven't been able to tell any difference between really leaning on the tamper versus a mild press with my fingers.
thirdcrackfourthwave
#1929: Post by thirdcrackfourthwave »
superdudeo wrote:What is the going consensus on tamp pressure with the robot? I think in the manual it says only a gentle tamp is required?
I think the tamp pressure is pretty irrelevant with the Robot. Gentle is enough. You really only need to get the 'air' out of the coffee. Just thinking out loud--if you pre-infuse and do a gentle ramp up. . . .I don't think I can tamp as hard as 7-8 bar. At any rate I haven't noticed a difference in the cup with regard to tamping pressure all other things being equal.
#1930: Post by thirdcrackfourthwave »
cooperpwc wrote:Here is an interesting article. It provides some support for the excellent results we get from the Robot at lower pressures:
This is the fourth thread on this board I've seen mention of this study. The authors concede the shot won't be as 'complex.' It seems as if it will be a thinner shot with less body.
"It is the over and under-extraction of flavours, combined, that gives coffee its some of its complexity.
A more efficient shot is likely to have less complexity, the scientists concede.
But they have a solution to that: brew two shots of espresso, one over-extracted and the other under-extracted, and mix them together. Genius.
Go on, ask your barista for one. If you dare."
It might have saved the café in Eugene 3200 USD but I figure it would save my household between 15-25 bucks ball bark a year and that is if I am not pulling two shots--one under extracted and one over extracted. If I'm only pulling one shot the body will almost have to be thinner. I can honestly say that in the past, while dialing in when I've pulled 7-15 seconds shots with about 15 grams and the shot was thinner and more sour than I like.
