Buying a lever espresso machine for coffee shop
gavijal
#1: Post by gavijal »
Hi all. Long time rider, first time poster here. For few months I have an idea to open specialized coffee shop with lever machine in it (to set apart from others primarily, but for the love of levers like a concept).
I have a few questions for tho. as I never used lever machine.
Are they good for "3.wave" modern espressos?
How to maintain them?
After long research I narrowed it (but I'm open to suggestions) to two machines
VA Athena Leva https://www.victoriaarduino.com/en/athena-leva-eng/
Or
Bosco Sorrento https://www.bosco-macchine.com/product% ... p?codice=2
One is a HX and other is dipper.
Which one is able to produce better shots, and which one is easier to maintain?
Ty all
baldheadracing
#2: Post by baldheadracing »
They're going to produce quite similar shots as the Athena has a flow restrictor to reduce pre-infusion pressure to dipper machine levels like the Bosco. The main difference would be which spring(s) they use.
As a dipper, the Bosco would be marginally easier to maintain, but the difference is very small.
Regardless, they're not going to be comparable to the La Marzocco Leva X for 3rd-wave espresso, assuming that the barista knows how to dial-in the options of the Leva X.
Good luck!
CafelatStore: home of Cafelat products online
Sponsored by CafelatStore
gavijal (original poster)
#3: Post by gavijal (original poster) »
Ty. So I should drop the idea to have 3. Wave espresso on machines like this?
LM leva is to modern for the look of coffee shop I'm planning.
baldheadracing
#4: Post by baldheadracing » replying to gavijal »
The machines would have to be setup for it, that's all. For example, adjusting a pressurestat to change brew temperature is simple, but not as simple as a touchscreen.
Markant
#5: Post by Markant »
What about ACS Vostok with thermoregulated groups?
#6: Post by gavijal (original poster) »
baldheadracing wrote:The machines would have to be setup for it, that's all. For example, adjusting a pressurestat to change brew temperature is simple, but not as simple as a touchscreen.
I just looked at leva x. It has it charm (not like a classic one) but damn, it's 2.5 times more expensive.
#7: Post by gavijal (original poster) »
Markant wrote:What about ACS Vostok with thermoregulated groups?
Looks great. What would be its advantages compared to 2 I linked?
BPlus: turning your coffee spirit
Sponsored by BPlus
Markant
#8: Post by Markant » replying to gavijal »
"Thermoregulated groups with independent regulation, double boiler, adjustable pre-infusion pressure, heating and reduced consumption times combined with a sophisticated and modern design, are the salient features of your Vostok."
What do you want more for 3rd wave coffee?
Don't know the machine; came across an advertisement for a second hand three group and it seemed to fit your requirements.
baldheadracing
#9: Post by baldheadracing »
gavijal wrote:I just looked at leva x. It has it charm (not like a classic one) but damn, it's 2.5 times more expensive.
It's a La Marzocco :wink:.
Videos of Greg Scace at home (and his La Marzocco Leva X)
MarvelousBiorr
#10: Post by MarvelousBiorr »
gavijal wrote:Ty. So I should drop the idea to have 3. Wave espresso on machines like this?
3rd wave espresso is much more heavily dependent on the grinder. Can you dial things in a bit more with more input control yes, but with a good enough grinder + burrs I am currently running some of the lightest coffee I have ever brewed on a Gaggia America from 1958 for a small pop-up coffee shop. That thing pushes out delicious berry and floral espresso with ease. That all being said the modern functionality of the Leva X is likely helpful for having several workers properly dial in that type of espresso. However, I run a Bosco one group at home and brew things from Saka level roasts up to greens passed gently over a candle flame and it handles all of it well. Using 98mm HU burrs or a Kafatek's SSW burrs allows for those to be pulled to a balanced shot in traditional ratios but the Bosco can actually pull up to 55g relatively easily so you can even push 1:3 shots if necessary.
TLDR; Any lever should be fine with the proper grinder for the shop + My vote is for the Bosco as I love what Roberta and the team are accomplishing.
