Building a lever machine.... from scratch - Page 49
That is a ludicrous amount of brass!
When I first saw the picture of all the different adapters and tees it seemed like overkill, but once you started to populate the boiler and the frame... that's about right. There's a lot of engineering and design that I was taking for granted in a modern lever machine.
- bidoowee (original poster)
Yup, lots and and lots of brass. There are a couple of assemblies that could be simplified with a custom part; but those are expensive. The input manifold especially is messy and unhelpful.
However, there isn't a lot of fat to be trimmed here if it all stays "off the shelf".
We're getting all hydraulic and electric!
All plumbing runs installed and tightened. Some re-tightened, gently sworn at, re-re-tightened, certain among which were loudly sworn at, replaced, tightened and re-tightened. Its a love hate thing.
I'm happier with the layout (hmm, drawing things in CAD first is actually helpful): the diagonal HX and smaller diameter tubing allow for a slightly simpler design and the virtual draft in the computer helped to eliminate a bunch of can't-install-this-because-that-is-now-in-the-way problems. The drain valve is now easily accessible right under the drip tray. I only put the steam tap on to, well, let off steam when I want to cool down the boiler quickly to continue working.
The new location and flange for AC distribution is far better than the previous version (i.e. there is one). I decided to switch to a terminal block rather than trying to accomplish everything inside the controller box. You can also see the T fitting that brings cold water to the HX and runs on to the expansion valve that at the sump.
Just below the T fitting is a bolt-on flange (made from a defunct IBM monitor stand) that supports the solenoid. No more free-hanging valves makes Sally the Solenoid happy:
All electrics and signal cables done. No checking for leaks - I just close my eyes when I turn it on.
Now its time to:
Image: Rafael Hoffmann
Now its time to:
OH COME ON!!!!!......
You can't just leave us hanging here.......
... and look at the time on the controller. I went home after that and haven't been back since.
Maybe it worked. Maybe I don't have a studio anymore.
Porridge will be shared tomorrow.
- arcus
Looking good and I'm confident the studio will still exist when you show up. Hopefully, the new group will be ready to install soon.
