Bosco Sorrento Update! - Page 3
That is an interesting noise. It as if I hear the metal stretching in its warmed up state? It also sounds a bit like dripping water in its tapping.
I will say that my PID lever is fairly quiet, once the warmed state is reached. There is always the noise of rushing hiss when temperature rises in water. But these two noises do not equal each other in terms of sound.
Once warm, my PID flashes briefly about once a second, for just a blip, this flatlines the temp, and the process is silent. However, my boiler is heavily insulated.
I second the notion of flushing all of the piping- steam, water, group, as well as letting it cool and emptying the boiler and refilling it. Trying different fill levels might yield different noises, or hopefully, no noises at all.
I use fitrete cartridge water filters, as well as a commercial sized softener, so I do not have to purchase distilled water. Well water is hard and has minerals here.
Good luck with it.
Good luck with it.
Thank you Nick!
If you can, there should also be a "b" value that you can get from the PID itself. You may also find that the settings in the PID may not align with what's in the book due to a lag between printing the manuals and updates in the machine's engineering.
Regarding the "b" value within the PID,not part of the parameter menu.If there is another way let me know.
Regarding the values for,
P.
L
d.
are the exact same as in the manual.
P.
L
d.
So when you restart the machine with the buttons pressed, you get F.03, P, I, D, and F.04 - but not b?
https://www.seattlecoffeegear.com/asset ... manual.pdf
Go to p.10.
Identical parameters and settings for current Izzo-vivi U.S. specs.
Go to p.10.
Sounds similar to Izzo Leva boiler noise troubleshooting helpPhaedrus wrote:
Here's the audio of the gurgle:
https://send.firefox.com/download/fb01b ... 8EpHflFZmw
Since the bottom of the machine is open, I stuck the iPhone underneath to record it. It's no where near as loud when you're standing in front of it, but nonetheless I don't think this is normal. I optioned it with a boiler drain so I don't mind doing a full flush, but first I have to wait for my local supermarket to restock the distilled water. People around here have been hoarding, it's not pretty.
Yes, it does seem so. I must say that it seems that the boiler fills more frequently than I anticipated. There was no solution posted in that thread. Waiting on a response from Bosco.
- JohnB.
How high in the water level tube is the water after the boiler fills? how low does it get before the refill kicks in?
LMWDP 267
